Procedure to eliminate the malfunction light from the spoiler.
Old Mar 9, 2008 | 12:54 PM
  #31
hydeaway's Avatar
hydeaway is infamous around these parts
Thanks for the write up.
Old Mar 10, 2008 | 05:22 AM
  #32
chenshan's Avatar
chenshan is a jewel in the roughchenshan is a jewel in the roughchenshan is a jewel in the rough
That's exact what I need. Thanks!
Old Mar 12, 2008 | 09:47 PM
  #33
contigo's Avatar
contigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant futurecontigo has a brilliant future
Pierre I have a large center Gemballa intercooler and I cant reach the harness to disconnect, any ideas how else I can do it, Can I play with the cables I see and tape the cable you mention?Name:  01 Blue Gemballa Eng (2).jpg
Old Mar 13, 2008 | 12:47 AM
  #34
996TurboOnMaui's Avatar
996TurboOnMaui is infamous around these parts
Originally Posted by dgreen78
I just pulled the wires and tied them together and taped up the hot ones. Theres no reason to spend money on a harness just to put a couple wires together.
OK...so I pulled all of the spoiler wires and tied the wires as the OP instructed but still get the malfunction light at 75 mph. dgreen78...which ones did you "tie together" and which "hot ones" did you tape up?
Old Mar 22, 2008 | 04:20 PM
  #35
daver's Avatar
daver is infamous around these parts
spoiler failure
I just picked up a 2001 996TT, had it checked out dealer told me everything was fine and car was clean, when i hit the right speed the spoiler goes up and then upon deceleration the failure light comes on and the spoiler remains in the up position. The rocker switch still lets me manually move it up or down. I am guessing it is not a fuse because the spoiler still functions up and down. Does anybody have any ideas ??? Thanks dave
Old Mar 23, 2008 | 07:04 AM
  #36
contigo's Avatar
No oil leaks from the wing? look on the wing motor and the hid lifts..
Old Mar 23, 2008 | 01:43 PM
  #37
daver's Avatar
thanks contigo, I will as soon as I get through some Easter family stuff
Old Mar 23, 2008 | 04:49 PM
  #38
Pierre996TT's Avatar
Pierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura aboutPierre996TT has a spectacular aura about
Originally Posted by contigo
Pierre I have a large center Gemballa intercooler and I cant reach the harness to disconnect, any ideas how else I can do it, Can I play with the cables I see and tape the cable you mention?Attachment 64064
I think you have to take the large center Gemballa IC out and then..reach the harness to work out the procedure.
Did you eliminated the 2 OEM IC's? check this out: G96 GTR 750 and look at the real bumper IC's openings
Old Mar 23, 2008 | 06:15 PM
  #39
contigo's Avatar
Pierre
That is a GTR which is based on a GT3 not on a TT so it is a completelly different car and system. No I have the three ICs on, I spoke with Orton (Neil) and he is doing the remap of my ECU and if we are able to reach the 1,3 boost as he thinks we will I will keep the car as I have it (that was his suggestion).
Old Mar 23, 2008 | 06:41 PM
  #40
contigo's Avatar
GTR Gemballa engine (base GT3)
Old Mar 23, 2008 | 06:44 PM
  #41
contigo's Avatar
GTR Gemballa engine (base GT3) installed
Old Apr 16, 2008 | 05:24 PM
  #42
raidentech's Avatar
raidentech is infamous around these parts
What's the part # for the TT harness? Is it plug and play?
Old Apr 16, 2008 | 10:18 PM
  #43
heavychevy's Avatar
Screw this, I'm going with the GT2 wing.
Old Apr 16, 2008 | 10:40 PM
  #44
DEEPBLUE's Avatar
DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !DEEPBLUE Is a GOD !
PM sent for part number as well. I have a partially failing RAM and decided to get the GT2 wing/front (thanks iA/Stephen) instead of repeated repairs, I will need the aerokit harness as well. Btw, the GT2 wing will save approx 80lbs over the hyd wing :-)
Old Apr 16, 2008 | 10:56 PM
  #45
heavychevy's Avatar
You getting the factory unit?
80lbs? That is not possible.
