To E-Gas or Not To E-Gas.. That is the Question
Old Jan 31, 2009 | 02:21 PM
Purplxd's Avatar
Purplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud ofPurplxd has much to be proud of
Hi all,
I've seen some interesting articles of people doing modifications and there seems to be some technical merit to knowing if your car is e-gas or not.
I have a 2001 996 C2 that was purchased in the US and I'd like to know first off, which is it, and how can I tell? Along with, what is the difference?
Cheers
Aaron
Old Jan 31, 2009 | 04:46 PM
Rickker's Avatar
Rickker is infamous around these parts
I'm pretty sure it is e-gas. I believe the '99C2s were the last 996s that had a cable throttle. The '99 C4s were e-gas models, at least the Canadian models were (I have one).
You can tell by looking at the throttle body. If there is no throttle cable hooked up, then it is e-gas.
...Rickker
Old Feb 1, 2009 | 06:31 AM
Redridge's Avatar
all 996 are egas... except the 99 c2.
Old Feb 1, 2009 | 10:50 AM
Purplxd's Avatar
That answered it, thanks!
Cheers
Aaron
Old Feb 1, 2009 | 01:47 PM
Breakthru's Avatar
Breakthru is infamous around these parts
Is there an advantage to having one over the other? I have a 99 C2.
Old Feb 1, 2009 | 02:31 PM
Doc_Porsche's Avatar
Doc_Porsche is infamous around these partsDoc_Porsche is infamous around these parts
i also have a 99 c2 but cab... however, i know it's not e-gas
Old Feb 1, 2009 | 03:25 PM
Redridge's Avatar
cable has better response, excellent for track.
egas is used for PSM, and power management (engine cutoff, more consistent pedal feel under load etc..) as well as slower throttle response time.
Old Feb 1, 2009 | 08:27 PM
Breakthru's Avatar
Ahhhh. Makes sense. Glad i got the cable then!
Old Feb 2, 2009 | 09:48 AM
Teuton's Avatar
Teuton is infamous around these parts
No left food braking in a e-gas car as well as it cuts throttle when you apply brakes. Just one of the reasons I choose a 99.
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
