Q: How to shift tiptronic for best 0-60 and 1/4 mile result?
Subscribe
Apr 23, 2010 | 01:20 PM
Okay manuals humor us tips.
And to all tip owners.
What is your suggestion shifting tiptronics to get the best 0-60 results or 1/4mile results?
i.e. at what rpm do you shift each gear, do you floor it on each gear, etc.,
Just wondering.
Reply
Apr 23, 2010 | 01:37 PM
Okay I need distractions big time for wanting that TPC single turbo set up...
Reply
Apr 23, 2010 | 03:50 PM
Manually shift into first, powerbrake and let her rip. As soon as you are moving, shift into the auto mode and let the tip do the shifting...it will shift at redline as long as you keep it floored.
My best time on my 99 tip with numerous mods and a slight (5%) downhill grade.
Reply
Apr 26, 2010 | 06:17 AM
Thanks for your info - never tried that before
Reply
Apr 26, 2010 | 10:57 AM
you dont have to switch it in auto mode...as long as you keep it floored in manual it switches for you at redline
Reply
Apr 26, 2010 | 12:59 PM
Very interesting info and thank you !
Reply
Apr 26, 2010 | 01:30 PM
Power break to what RPM?
Reply
Apr 27, 2010 | 04:16 AM
what RPM should it be before brake release for the best launch?
Reply
Apr 27, 2010 | 10:39 AM
this doesn't apply to a c4s right?
due to awd... ??
Reply
Apr 27, 2010 | 11:13 AM
Quote: due to awd... ??
Sure you can.
Reply
Apr 27, 2010 | 11:15 AM
nevermind... doen't matter if its DBC or DBW
Reply
Apr 27, 2010 | 11:23 AM
ok more detail
Quote: Sure you can.
how about on a 2002 c4s ?
Reply
Apr 27, 2010 | 01:12 PM
Quote: how about on a 2002 c4s ?
I don't see why not...look at the turbo tips....they do it all the time
The limiting factor is the TC stall speed...I'm not sure what the 996's have..
Just hold the brakes down as hard as you can.....start applying throttle till the car starts to move forward a little...that'll be the max rpm you can hold it to....release the brakes and off you go...
The rpm you can do that can be raised with a higher stall TC but I'm not sure anyone has come up with one....EVOMS has one for the 996 turbo's but I'm not sure if they fit on a regular 996
Reply
Subscribe
