Door Adjustment
Old May 29, 2011 | 08:24 PM
2001Porsche911's Avatar
2001Porsche911 is infamous around these parts
Door Adjustment
Hi Everyone,
On my 04 C4S I feel like I have to slam the drivers door to get it to shut properly, the passenger door can be closed lightly and it latches but the driver door does not close unless I slam it shut. Is there a way to adjust the lock mechanism? Anyone every done this?
Old May 31, 2011 | 06:15 AM
aemr1968's Avatar
aemr1968 is infamous around these parts
I have same issue...
Old May 31, 2011 | 08:04 AM
Zookie's Avatar
would like to knwo as well
Old Apr 24, 2015 | 08:37 AM
dan_189's Avatar
dan_189 is infamous around these parts
Hey all, hate to revive such an old thread but looking for some advice on door adjustment. Haven't been able to find much...
Passenger side door is quite easily closed, drivers side requires a little more force? Is it a simple case of lubricating the inner latch mechanism? Or is it more complicated and requires the striker/catch on the door jamb to be adjusted?
Thanks!
Old Apr 25, 2015 | 09:56 AM
Slider's Avatar
Have you confirmed this with the windows open? The last door closed is always a little harder because of the air pressure within the car. Make sure you are not taking the door apart for nothing...
Old Apr 25, 2015 | 02:22 PM
geetee's Avatar
geetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant futuregeetee has a brilliant future
very easy to adjust. loosen the 2 triple square(don't use a star bit or flat head as you will strip it) on the latch that's on the body. Move it just a little and tighten. Try closing. Repeat until the door closes easily
Old Apr 25, 2015 | 11:44 PM
dan_189's Avatar
Thought so I don't think I have access to that style of head. What's it's official name?
Also on the lubrication is some silicon spray okay?
Thanks!
Old Apr 27, 2015 | 07:26 AM
dan_189's Avatar
Hey all have been able to find triple square bits, what size do I need?
Thanks!
Old Apr 27, 2015 | 11:28 AM
geetee's Avatar
triple square....I think it was a size 8mm...I can check when I get home
Old Apr 29, 2015 | 07:21 PM
dan_189's Avatar
Hey all, anyone have the chance to check the size?
Thanks!
NIKAS
Aug 20, 2019 07:53 PM
davetherave
Bentley
Sep 16, 2015 06:30 AM
davetherave
Bentley
Sep 11, 2015 04:15 AM
sparks
Sep 8, 2015 03:03 PM
