Has anyone done a 3.4 to 3.6 996.2 or 997.1 complete engine swap?
Old Aug 10, 2012 | 01:48 PM
Black_911's Avatar
Black_911 has a spectacular aura aboutBlack_911 has a spectacular aura aboutBlack_911 has a spectacular aura about
How much will the swap cost roughly?
Is it worth it for the power?
New Porsche guy sorry.
Old Aug 10, 2012 | 02:19 PM
chsu74's Avatar
chsu74 is infamous around these parts
its not worth it. sell you car and buy a turbo.
Old Aug 10, 2012 | 03:01 PM
Black_911's Avatar
Just being curious. I like the N/A engine.
Old Aug 10, 2012 | 07:45 PM
stephan_porsche's Avatar
stephan_porsche is infamous around these parts
Turbocharger!
Old Aug 11, 2012 | 03:18 AM
Black_911's Avatar
Originally Posted by stephan_porsche
Turbocharger!
Maybe.... aftermarket
Originally Posted by aRgH
What are the circumstances? Are you going through a rebuild? or is your engine fine and you're just curious for kicks? If I were doing a rebuild and I owned a 3.4 996, I would definitely do a 3.6 swap from a later 996.2. When I did the rebuild on my 01 3.4 C4, I wasn't quite sure what to do. Whether I should bore my 3.4 to a 3.6 and go with (aftermarket parts), or just stick with OEM. I called a ton of shops and all of them had mixed opinions. A lot of them liked using aftermarket parts because its cheaper, but there were actually more shops that recommended sticking with OEM because they all said its (Porsche) they're not exactly using cheap materials to build there 14k+ engines. 1 shop in particular definitely didn't like using aftermarket pistons, heads and so on... because he owns a big reputable race shop here in CA and hes had various complains of owners blowing there engines on the track and just sticks with OEM. Anyways, I finally made my decision and just stuck with OEM. I purchased a used low (mileage 32,000) 3.6 C2 996.2 engine for $6,500 + $1,800 labor and have no regrets. And from what I hear upgrading from a 996.2 3.6 to a 997.1 3.6 is about the same thing (labor wise). Just my 2 cents. Hope this helps.
Thanks for the input definitely gave me an idea.
Old Aug 12, 2012 | 03:03 PM
Byprodriver's Avatar
Byprodriver is infamous around these parts
Best Option here : https://www.6speedonline.com/forums/...gine-sale.html
Old Aug 12, 2012 | 03:16 PM
Only a 25HP differnce between and 3.4 and 3.6. The 3.6 achieves it with the Vario-Cam. Both engines had the same rate of failure on IMS. Some people think the 3.6 had less but that is not true at all. Both engines suffered about a 10% failure rate however IMS failure happens around 20,000-40,000 miles. My pre-modded engine had 106,000 with the orginal IMS with no problems. The 3.4 has a bad wrap but is a very strong engine! Its down fall is poor cooling, once upgraded with a 3rd Raditor and lower temp thermostat it has no issues.
Old Aug 13, 2012 | 01:10 AM
kchociej's Avatar
kchociej is infamous around these partskchociej is infamous around these parts
Where did you get the 10% failure rate number?
Just curious...because it seems really high!
Old Aug 15, 2012 | 12:47 PM
The 3.6 makes 15 ft./lbs more torque too & that is something you can feel & use. The weak point of the MKI 3.4 is the thinnest cylinder walls of any M96 engine & the main reason Porsche redesigned the case for the 3.6. The thin cylinder walls is why LNengineering.com sleeves are needed for a complete rebuild.
Jul 29, 2019 11:13 AM
joseph_number1
Jul 19, 2018 05:45 PM
Konea420
Aug 25, 2015 09:44 AM
