Evoms V-Flow Air Intake.. (y) or (n)?
Old May 31, 2007 | 09:59 AM
  #61
GOB's Avatar
GOB
GOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud ofGOB has much to be proud of
I know its for a 997, but the CF airbox that Champion sells goes for $3,000! They say it will give the car 10-12hp, but they rather push a Tubi exhaust for $500 less and similar performance gains. Either way, that is a lot of money for an airbox!
Old May 31, 2007 | 10:21 AM
  #62
Benjamin Choi's Avatar
Benjamin Choi is infamous around these parts
can't say this enough... don't mod your n/a 911 with intake and exhaust for "performance gains" else you look really silly justifying $$$$$$$ for puny additional power
Old May 31, 2007 | 01:18 PM
  #63
Redridge's Avatar
I did the silly mods you state... it helps, especially if you want more gain and decide to S/C... If you have it in your budget and have all your priorities right why not mod it... it is their $$$$$$$
Old May 31, 2007 | 01:35 PM
  #64
p0rsch3's Avatar
p0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond reputep0rsch3 has a reputation beyond repute
I don't get it, can you clarify why not? These minor and relatively inexpensive additions do provide noticeable positive benefit.
I personally do not plan on dropping $10k in engine mods on my NA tiptronic pcar...
If I wanted that much additional gain in power I would sell it and put the large $ towards a used TT (which I may do, eventually...).
Old May 31, 2007 | 02:07 PM
  #65
RocC4S's Avatar
RocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant futureRocC4S has a brilliant future
Originally Posted by John Romano
It is interesting how no one from EVOMS has chimed in to defend their product or to offer any of us with problems some resolution. One thing for sure, I would NEVER spend another dime with EVOMS. I don't care how good their airbox sounds or how good it works, that POS V-Flow fell apart within a year and NEVER fit right. So much for all their R&D. What's the point of packaging it in a Chinese POS?
+1...I couldn't have said it any better.
Old Jun 2, 2007 | 03:16 PM
  #66
Porschinator's Avatar
Porschinator is infamous around these parts
One guys garbage is another guys treasure. I have no complaints with the K&N and honestly it was simple to install. I guess it depends on how mechanically inclined you are. It is a pain in CA for any intake kits since non are CARB exempt and eventually have to be swapped with the OEM bow before SMOG check. Also K&N is a big name and may not be the prettiest intake but always well made and fits!
As for power gains. YES it is true that you cannot gain high out put from intake and exhaust...even ECU upgrade on non-turbo rides. But gains can be made and if you can get a good deal then why not?
Old Jun 13, 2007 | 11:09 AM
  #67
C4SSS's Avatar
C4SSS is infamous around these parts
This thread didn't really yield any results.. and now I know why EVO have not bothered to improve their product...There is nothing like it in the price range. Abviously the K&N is there but it has some issues with being used in all weather.
So should I just give in and get a Evoms V-Flow? No Satisfied customers out there?
Old Jun 13, 2007 | 11:30 AM
  #68
GOB's Avatar
GOB
The K&N has been revised for all weather an apparently the use of some sort of a "sock" will make it all weather. Me? Well, I ended up doing the muffler bypass. When they get to be too much (as they did already), then I will get the K&N.
Old Jun 13, 2007 | 03:42 PM
  #69
John Romano's Avatar
John Romano is infamous around these parts
I'm not saying the V-Flow doesn't "work," I'm just saying its execution leaves a lot to be desired. For the money - or even a little more - it should be made from better material and better put together (B&M SSK is a good example). It works fine (I don't imagine I'd be saying that if moving parts were involved) and it sounds good, esp. at WOT. You're just not going to be showing off your engine bay.
Old Jun 13, 2007 | 06:33 PM
  #70
996Jammy's Avatar
996Jammy is infamous around these parts
yo porsch3, did u decide not to put the drycharger sock on the filter? Also, seems like you didn't adjust the rubber boot when reinstalling the MAF sensor so it looks like wires are still pointing left instead of right. of course, no big deal...just fyi...
danyoP4S
Sep 30, 2021 05:06 AM
iammulva
Sep 7, 2015 03:06 PM
