Questions on doing a 3.8 or 4.0 conversion
Old Feb 23, 2012 | 04:18 PM
Boca's Avatar
Boca is infamous around these partsBoca is infamous around these parts
Hey Folks,
Can anyone enlighten me with their knowledge or experience on stroking the 3.6 engine.
I am looking to make a solid and real 800+awhp on 93 octane and I assume stroking is the only way to that end.
Old Feb 23, 2012 | 06:59 PM
skeeter's Avatar
skeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond reputeskeeter has a reputation beyond repute
Originally Posted by Boca
Hey Folks,
Or if you have a built motor with stock displacement and e85, I'm sure you could do it no problem...On 93, I'd guess you'd have to stroke it, but not sure what it would put down...
Old Feb 23, 2012 | 10:20 PM
Slick997's Avatar
Slick997 is infamous around these parts
been going over this myself and seems the only way is with a 4.2l or4.3l, no other way.
Old Feb 24, 2012 | 01:16 AM
MannschaftQ8's Avatar
MannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the roughMannschaftQ8 is a jewel in the rough
750whp @17-18psi on 91 octane still not bad I guess.
Old Feb 24, 2012 | 02:54 AM
wrenchnut's Avatar
wrenchnut is infamous around these parts
750plus requires upgraded head studs for the increased boost levels, you can pull this off with a 3.6
Old Feb 24, 2012 | 01:25 PM
Slick997's Avatar
750awhp with a 3.6? please tell me how?
Old Feb 24, 2012 | 01:26 PM
Slick997's Avatar
Talking on pump gas. 93
Old Feb 24, 2012 | 01:35 PM
Slick997's Avatar
Did u get your car back? Mine was there same time as yours, i think. R911, was thinking about doing the flex fuel.
Old Feb 24, 2012 | 02:20 PM
wrenchnut's Avatar
Alpha 3076 push through 30psi ,, suck through most likely the same
wrenchnut's Avatar
Need meth as well
Old Feb 24, 2012 | 02:32 PM
Tom@Champion's Avatar
Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !Tom@Champion Is a GOD !
Boca, take a look at these threads. We've done that power level with VTG's on an upgraded 3.8L. It can be done easily...just takes time and $$ unfortunately.
Build Complete.......for now.
3.8L VTG GT2 Upgrade Taking Shape...
Also, you can take a look at this gallery for pictures of some of the parts we use and modifications we do to the engine.
http://www.flickr.com/photos/champio...7626127858868/
We've done it with VTG's on a 3.6L. Rods, pistons, 68mm VTG's and a decent helping of boost gets you there.
Old Feb 24, 2012 | 05:25 PM
Hey Folks,
I believe ur target is possible with 3.8l if ur tuner lower the torque and boost it up u will still be able to get ur target on 93 octane also. On 750whp that I'm talking about u will be able to kill bolt ons Gixxers/Busa's with no problem. We r talking about 670wtq@4500rpm.
Again...This 750whp/670wtq@17-18psi on 91 octane. You will see more power with 93 octane of course.
Old Feb 24, 2012 | 06:41 PM
Nasser's Avatar
Nasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant futureNasser has a brilliant future
I think you can make 800whp on carrilo rods, L19 head studs and porting
+ Protomotive GTX3076 turbo kit
low boost 17 psi pump gas
hight boost 26 psi ms109 or e85
Old Feb 24, 2012 | 10:11 PM
Slick997's Avatar
The 3.8,s are making 750whp on pump gas, 3.6? Really? I wanted 800 to 850whp on 93 only. No meth. So 4.1 to 4.3 seems to be the way to go.
Old Feb 25, 2012 | 02:02 AM
91 octane no meth it made 750whp. Why u don't go with E85 instead of 93 octane? it will cost u less than 3.8 build. Forged internals + E85 would be way to go IMO
