Oil change issue
Old Aug 13, 2012 | 04:42 PM
White911ttOne's Avatar
White911ttOne is infamous around these parts
Oil change issue
Hi Guys ,
I recently did my oil change on 09 911 tt and only about 3 quarts of oil came out. I have read all the DIY on this subject so I followed the instructions, filled it back up with 3 quarts ( did not over filled the motor - thank god ) and the oil gage shows full bars after warm –up. What gives? Oh, I did drive the car before putting it on the stands so it was warmed up befor draining the oil and doing the full service (belt, spark plugs, fuel filter, air filter and the oil change). Any suggestions? Thanks <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 13, 2012 | 05:02 PM
jhbrennan's Avatar
Originally Posted by White911ttOne
Hi Guys ,
I recently did my oil change on 09 911 tt and only about 3 quarts of oil came out. I have read all the DIY on this subject so I followed the instructions, filled it back up with 3 quarts ( did not over filled the motor - thank god ) and the oil gage shows full bars after warm –up. What gives? Oh, I did drive the car before putting it on the stands so it was warmed up befor draining the oil and doing the full service (belt, spark plugs, fuel filter, air filter and the oil change). Any suggestions? Thanks fficeffice" /><O></O>
Sounds like you just drained the crankcase and forgot to drain the oil tank. It's pretty well explained and illustrated in the DIY - https://www.6speedonline.com/forums/...-m97-70-a.html
Old Aug 13, 2012 | 06:38 PM
Thanks, but i did remove the two screws shown in the pics below. Is there something that i'm missing?
Old Aug 13, 2012 | 07:42 PM
jhbrennan's Avatar
yes - you still haven't drained the oil tank - you have just drained the crankcase. Your pictures are from Rennlist - look at the first two pictures in that set of 4 and you can see what the drainplug for the oil tank looks like.
Old Aug 13, 2012 | 07:59 PM
I'm sorry, but the pics attached to that DIY are not viewable, they have X over them. Any suggestions where one can enquire a diagram or a pic of the oil tank<?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
Old Aug 13, 2012 | 08:05 PM
jhbrennan's Avatar
Get them from the same place you got the pictures you posted - they are from a post on Rennlist.
http://forums.rennlist.com/rennforum...diy+oil+change
Old Aug 13, 2012 | 08:48 PM
bbywu's Avatar
Pics are down because of Apple sucks and closed MobileMe.
Here's what you want to drain:
Old Aug 13, 2012 | 09:39 PM
LMAO, well that explains everything- I am a dusche. Thanks, will get it done over the weekend. Im just glad the spark plugs are done, that was a pain in the a$$.
Old Aug 15, 2012 | 11:42 AM
tssci's Avatar
tssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to beholdtssci is a splendid one to behold
Caution..
when loosening the oil tank plug, make sure you have a wrench on the fitting just above it to apply counter-torque to avoid damage/ripping the weld out...
Old Aug 15, 2012 | 11:53 AM
Thanks for your help you guys, will finish the oil change this weekend
COBB Tuning
Jan 1, 2025 09:02 AM
SharkyShark20
Sep 19, 2015 09:54 PM
BLKonBLK911C4S
NorCal
Aug 29, 2015 03:20 AM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
