Urgent: Dead Battery and can't open the lid
Old Oct 21, 2012 | 12:05 PM
quick's Avatar
quick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant futurequick has a brilliant future
I re-opened an older "Dead Battery post" in 996 TT thread but nothing seems to be working.
I ried with the donor battery/cables but the lid latch in the car won't open the lid and my key is stuck in the ignition
I can't seemto find my second key.
What else ca I do? What's the location of the cable in the passenger side foot well that can open the lid.
Old Oct 21, 2012 | 12:29 PM
w00zy's Avatar
w00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to beholdw00zy is a splendid one to behold
A Ctek with cigar plug adapter would solve that problem
Sometimes the battery is dead and can't be charge through the cigar plug but it's enough to give some power so you can open the lid.
Old Oct 21, 2012 | 01:23 PM
jhbrennan's Avatar
If your key is stuck, not sure what good the second key will do. IIRC, the cable can be accessed though the front wheel well after removing some of the inside panels. Search and you should find some detailed info plus pictures.
Old Oct 21, 2012 | 01:59 PM
imcarnuts's Avatar
imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !imcarnuts Is a GOD !
Try using the donor battery process but instead of using the latch on the car to try and open the lid, use the lid button on the key. Not sure if it will work since key is stuck is the ignition. Note #6 in the attached instruction. This is from the 997 so may be different.
File Type: pdf
Old Oct 21, 2012 | 02:42 PM
TT.BRN's Avatar
TT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond reputeTT.BRN has a reputation beyond repute
Been there ...
First use the donor battery method (make sure you're doing it correctly) to remove the key, then use the trunk button on the key to open the boot ..
Make sure you have good contact with the red fuse, you should hear a click sound when you connect the black lead to the door latch ....
Good luck .. Tell us how it goes
Old Oct 21, 2012 | 06:55 PM
quick's Avatar
I think that seems to be the problem as the clamps on the cables have a bit of over hang and I was using just one side of the clamp on to the fuse
I will try to get a newer cables that would clamp head on (the front part) rather than just one side...
Will report back as soon as I get hold of newer cables.
Old Oct 21, 2012 | 07:46 PM
jhbrennan's Avatar
Maybe you didn't have the fuse box positive terminal extended far enough - it takes a good pull. At full extension you should be able to hook up the cable without any "overhang".
Old Oct 21, 2012 | 07:52 PM
quick's Avatar
Update
Well a mechanic friend came over and played with the cables and the fuse and got it opened up.
However he wanted to jump start the car and on the second attempt the PSM failure came up on the dash so I didn't let him try again.
The car is on battery charger now until it's all charged up.
What about the PSM failure? Is that just the code that needs to be cleared?
Thanks to all who took time and helped.
Later
...Note.... Read the archives and figured out the PSM code is a normal thingy and will clear out with few miles of driving.
Old Oct 21, 2012 | 10:43 PM
TT.BRN's Avatar
Not miles ... Meters ..
Glad things worked out ...
P.s. some batteries are a lost case, and with the battery configuration in these cars I didn't risk another lock-out and got myself a new unit ...
Cheers
Old Oct 21, 2012 | 10:53 PM
SeattleBum's Avatar
SeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud ofSeattleBum has much to be proud of
Cheers
My car arrived with a dead battery (used). The new battery only lasted 2 years (Optima red top).
Old Oct 22, 2012 | 10:32 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
PSM light will go away once you drive it. It can be trigger by loss of power.
PV=nRT.
Sep 9, 2022 06:06 PM
jaehoppa
Oct 22, 2015 09:17 PM
Korntera
Sep 15, 2015 08:20 PM
oo7
Sep 10, 2015 08:08 AM
DetomasoGTS74
Sep 7, 2015 09:42 AM
