997TT MK.1 PCM 3 conversion DONE :)
Rating: Thread Rating: 2 votes, 5.00 average.
Old Jun 18, 2016 | 03:35 AM
  #496
997tt_'s Avatar
997tt_ is infamous around these parts
I mad an adapter and so i couldnt see if all wires are connected or not.
This one was not connected due to a mistake.
I now checked the wiring and all except the Wake UP Diagnosis are connected.
Is it right when i connect this one to a16 at the pcm3?
Old Jun 18, 2016 | 03:56 AM
  #497
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
adapters are evil
correct
Old Jun 18, 2016 | 04:01 AM
  #498
997tt_'s Avatar
Now i know this, but at the beginning i thought if i would ever change back to the pcm 2.1 it would be easier.
Thanks i will put the pin in.
Old Jun 18, 2016 | 04:40 AM
  #499
isysman's Avatar
isysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond repute
Originally Posted by Serg124
theories??? on page 19 here I wrote that 09 turbo ac unit work, why etc. but you can buy this unit only new, and expensive. and there is alot used units on ebay, which also can be used but with lot of work. all this mess was around that cheap used units.
I know you did but there was talk about sensors being added and resistors etc. None of that we could ever get to work and eventually it wasn't needed, just the reprogramming in piwis.
We were also unable to get the gen.2 units to work regardless of any instructions in here and also trying our own things.
Old Jun 18, 2016 | 05:03 AM
  #500
Serg124's Avatar
and you blame me that you cant do something? ))) what a nonsense.
Old Jun 18, 2016 | 05:08 AM
  #501
isysman's Avatar
Did I blame you? No I said we were unable to make those ideas work. I didn't think Russians were so sensitive!
Old Jun 20, 2016 | 09:00 AM
  #502
997tt_'s Avatar
Does anybody know where i can order the plug of 99761353981A05
The old one does not fit (it is to big)
And maybe someone knows if the pins in the plug are the same on the 997/1 generation and with the 997/2 generation.
Old Jun 20, 2016 | 09:15 AM
  #503
isysman's Avatar
What does the plug connect to? Maybe I can answer but I need to know what that plug is for.
Old Jun 20, 2016 | 09:19 AM
  #504
997tt_'s Avatar
To the "Sport Console" from the GT2RS which is for PASm and Traction+Stability control
But the plug from the old console is bigger and wont fit into the new console.
Old Jun 20, 2016 | 09:32 AM
  #505
isysman's Avatar
You have to remove the outer case of the loom plug, and some rewiring is involved as well. Once you remove the outer case you'll find there are more pins on the back of the new strip than there are holes on the loom plug. You just fit it at the end of the pins.
Old Jun 20, 2016 | 01:48 PM
  #506
997tt_'s Avatar
My old one has 23 pins (Reading from wiring diagram)
The new one has 21.
And as much as i see the new one only has LED1 and no Status LED 2, Status LED3.
Also Old one has Input PASM UP Down on A2, where the new one has Button Signal on A2.
All other pins are the same.
Old Jun 20, 2016 | 02:02 PM
  #507
Serg124's Avatar
))) suit youself, I'm off
Old Jun 21, 2016 | 12:32 AM
  #508
997tt_'s Avatar
Another question at pcm3 do you have the data from the dashboard like actual trip, milage etc. - Or only the point with Clock and the range how long the fuel lasts.
Can this be coded to have those settings?
Also the individual settings for climate control, locking etc.?
Old Jun 23, 2016 | 01:57 AM
  #509
997tt_'s Avatar
Hello Guys,
does anyobdy have a porsche, audi or VW part number for the needed pin of the climate console which has to be repinned?
I have the mousser number, but they want 20eur for shipping.
http://www.mouser.at/ProductDetail/TE-Connectivity/929950-1/?qs=%2fha2pyFaduhp959FvVJoDi9W8rCpaZdfPhCPc3iorzI% 3d
I asked Porsche but they say they do not have a pin for this and they do not know how to get this.
Before spending 20eur for shipping, maybe someone has an idea where to get this pin?
Old Jun 23, 2016 | 02:10 AM
  #510
isysman's Avatar
Hello Guys,
I had a spare loom that I took from and spliced in.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
