997TT MK.1 PCM 3 conversion DONE :)
Rating: Thread Rating: 2 votes, 5.00 average.
Old May 16, 2016 | 04:36 AM
  #466
Serg124's Avatar
Serg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond reputeSerg124 has a reputation beyond repute
keep reading my previous post until full understanding! you can't omit INPUT wires!
Old May 16, 2016 | 10:06 AM
  #467
atomicfan's Avatar
atomicfan is infamous around these parts
Am i missunderstanding that these cables are for new brown plug behind the pcm?
But i mean the black plug at the ask amp.
I couldnt find these cables in a wiring diagram for the pcm?
Old May 16, 2016 | 10:35 AM
  #468
Serg124's Avatar
I dont know why is that, I do see them clearly
Old May 16, 2016 | 10:37 AM
  #469
atomicfan's Avatar
Where?
If i open MJ 2009 pcm i can see:
B2 Front Right +
B8 Front Right -
B1 Front Left +
B7 Front Left -
B4 Rear Right +
B10 Rear Right -
B3 Rear Left +
B9 Rear Left-
But not:
B2 In Front Right +
B8 In Front Right -
B1 In Front Left +
B7 In front Left -
B4 In Rear Right +
B10 In Left Right -
B3 In Rear left +
B9 In Rear Left-
which are at the new ask amp.
If i follow them it opens a PCM for Japan.
In the Europe one those cables are not present.
The old cables without in are already at the pcm.
Old May 16, 2016 | 10:41 AM
  #470
Serg124's Avatar
no, you wrong.
Old May 16, 2016 | 10:52 AM
  #471
atomicfan's Avatar
This is the wiring diagram for the ask amp or?
Ok i see one pair is for japan and the other not.
But are these cables not the same as at the ask amp 2008 which are not IN?
I mean except the IN before the title they are completely the same?
On the white socket i already switched all cables front, right dashboard, door etc.
So these cables should already be behind the pcm where i have to make the new bronw socket?
Old Jun 10, 2016 | 03:00 PM
  #472
frogman's Avatar
frogman is infamous around these parts
I've started a new thread on this how to. but thought it appropriate to mention it here as well. HVAC upgrade done
Firstly many thanks to Monster, Slackster and issysman for their collaboration and the hundreds of emails that went back and forth to make this work.
After lots of work, In the end the fix is fairly straightforward….
How to upgrade your Porsche 997.1 to 997.1.5 HVAC (identical physically to Gen 2)
Firstly this only works with what we call the Gen 1.5 or 2009 997 Turbo unit – Gen 2 units won’t work with this fix the firmware is different to take account of the different wiring setup and compressor.
The part numbers are:
997.653.205.xx No heated seat version
997.653.215.xx Heated seat version
997.653.225.xx Heated and ventilated seat version
Where xx denotes Porsche version updates. These are available from OPC or Teile. You wont find one second hand they are very rare being only from 2009 Turbos.
Once you get your hands on one then you need to do the following:
Remove your old HVAC unit. To do this:
1. remove the small carpet piece from either side of the centre console held in place with a torx screw. Then remove the 2 small torx screws holding either side panel in place. Then sit in a seat and placing your grip at the rear of the side panel slide the side panel forwards towards the rear of the car, a good jerk will be required to unclip it.
2. At either side of the HVAC unit there is a spring clip. Push both in at either side and slide the unit out.
3. There are 2 connector blocks black and red in colour.
4. What you need to do now is remove the wire from B16 in the red block, the pin holes are numbered on the bottom of the block. Make sure you get the correct one…
5. This wire needs to go in the empty slot in D14 on the black coloured block. Pins for this are available from TE connectivity or get an old gen 1 loom and take out a spare from there.
6. On the Gen 1.5 and 2 Version there is an Evaporator temperature sensor connected to the now empty B16 and ground but you don’t need this it works fine without….
7. Reassemble everything that you you just took apart in reverse order.
8. You need to recode now with Piwis version 2 - Piwis version 1 won’t do this part. If you get OPC to do this it’s a 15 min job Max but they will probably try to charge you an hours labour – ask if you can watch….
9. You will need to activate your new HVAC unit by doing a vehicle handover operation in Piwis then change Compressor setting from external to internal setting in the A/C controller in Piwis.
10. If you followed everything correctly your done. Enjoy your new Freezing cold AC.
Old Jun 11, 2016 | 03:57 AM
  #473
isysman's Avatar
isysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond reputeisysman has a reputation beyond repute
^^^What he said!!!
Old Jun 11, 2016 | 11:05 AM
  #474
atomicfan's Avatar
Can anyone help me with the conversion from no bose (ask amp).
I have a new loom from the ask amp b1-b10 direct to the pcm3.
But i have no sound at all.
I can code the pcm3 to 997 or 987, 997, GT2, GT2 without Klangpaket ASK.
Do i need to code other parts or how can i get sound?
Old Jun 11, 2016 | 12:55 PM
  #475
Obb's Avatar
Obb
Obb has a spectacular aura aboutObb has a spectacular aura about
Anyone have a full list of part numbers for it now that its all figured out?
Old Jun 12, 2016 | 03:42 AM
  #476
Serg124's Avatar
Originally Posted by isysman
So to all doing this upgrade. One of the issues that was never really resolved properly was getting the AC/HVAC unit to work to trigger the AC compressor. There are some theories on here about needing to out a Evap sensor in the wiring etc. but none of that is needed. A group of us in the UK have been working on this and one of the team cracked it. It turns out it was a very easy fix. As I was not the team member who did it I will divert you to a thread were you can read it step by step. It turns out it's just a PIWIS setting.
theories??? on page 19 here I wrote that 09 turbo ac unit work, why etc. but you can buy this unit only new, and expensive. and there is alot used units on ebay, which also can be used but with lot of work. all this mess was around that cheap used units.
Old Jun 12, 2016 | 03:43 AM
  #477
Serg124's Avatar
good job anyway!
Old Jun 12, 2016 | 09:08 AM
  #478
997tt_'s Avatar
997tt_ is infamous around these parts
Many thanks to this Thread.
I have done the conversion today and have one problem with the radio or better saying with the loudness.
It seems that only the door speakers work and that the soundlevel is not very high.
I put the volume to the max, but this is not very high. Especially when you drive.
I have a 997 Turbo with (unfortunatley) no exta equipment and no bose.
I bought an ask amp as per the picture here in this thread and installed it to the pcm3 and the old speaker cables as per the wiring diagram.
Did anybody had the same problems?
Old Jun 12, 2016 | 09:31 AM
  #479
Serg124's Avatar
you did it yourself or?
make a photo of your amp, number on it, and plug with wires.
and make photo of pcm connector.
low volume = pcm work without amp. dont go max level - you will burn pcm output.
Old Jun 12, 2016 | 09:49 AM
  #480
997tt_'s Avatar
Yes i did it myself.
I bought the amp from a company that checked it before. (All channels work, they wrote on the invoice after testing).
I read the wiring diagram and made a loom from the amp to the pcm3.
(As my old one only had 1 connector, and the new one has 2)
At the pcm i inserted the new wires from the amp in a quadlock and i soldered the old speaker cables front right-, front right+, front left+, front left- to the new wires which came from the amp.
This is shown in the wiring. (The cables from the old speaker go to Door and 2Way Speaker - each + and -)
I will make some pictures as soon as iam back in the garage and get the cover panels out.
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
