Led fog conversion
Old Feb 14, 2014 | 07:58 PM
eNVy997tt's Avatar
eNVy997tt is just really niceeNVy997tt is just really niceeNVy997tt is just really niceeNVy997tt is just really nice
Led fog conversion
Anyone done this? I am thinking that a simple bulb swap could really update to look of the fogs on 997tt's. There may be a need for some resistor or something, but that is in fact the question. I assume some of the guys here have given this thought already???
Old Feb 14, 2014 | 08:02 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Yes, you can do it. You can buy the LED's with the correct circuit to prevent the bulb out warning. I have done this on mine, and think they look pretty good.
DC
Old Feb 14, 2014 | 08:10 PM
eNVy997tt's Avatar
Nice! Got pics? Any chance you'd like to point me in the right direction for bulbs like the ones you mention? I get emails daily from ddm tuning about led sales and blowouts... Maybe they can be found there?
What are the stock bulbs?
Old Feb 14, 2014 | 08:40 PM
Ryane8182's Avatar
Ryane8182 has a spectacular aura aboutRyane8182 has a spectacular aura aboutRyane8182 has a spectacular aura about
I've done the same. It looks great. I actually got mine from a guy who gave great customer service. Easy install. I'll see if I can find the site.
Old Feb 14, 2014 | 08:44 PM
therock88's Avatar
Sure...Not the best photo but you get the idea. The bulb is H3, you get the LED and you need to reverse the polarity....they fit the same other than that.
Check this thread on this site:
https://www.6speedonline.com/forums/...available.html
Old Feb 14, 2014 | 09:07 PM
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Subscribed. I've seen several options on eBay. Seems they usually need resistors.
Old Feb 14, 2014 | 09:19 PM
therock88's Avatar
If you get the ones with the proper circuit built in, no resistors needed at all. If you buy the super cheap ones that DO NOT say no-can bus error, you will need reisitors. So when you search, I would suggest "H3 LED fog Canbus".
To match Porsche HID headlights(OEM's are about 5300K), you want between 5500K - 6000K temperature light. Lower than 5000K looks yellow, and higher than 6000K starts to look too blue.
Click this link: LINK
This may help also:
DC
Old Feb 14, 2014 | 09:56 PM
VID997's Avatar
VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !VID997 Is a GOD !
^^^therock
What are you using for your side marker LED's? I've tried several from $8.99-$29.99, all have thrown codes. I did buy a set of side markers from Nello, but I wanted them to be "on" and white when not in blinker mode. They didn't throw codes but they did not function as I was hoping for.
Old Feb 14, 2014 | 10:12 PM
VID997's Avatar
Below are images of what I am currently running. All supplied from MaxSpeed Motorsports (Nello) other than the side markers.
ID:	334316   Click image for larger version
ID:	334317   Click image for larger version
Old Feb 15, 2014 | 04:17 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Best looking fog lights are from 997.2tt...they cost a lot but are simply awesome...
Old Feb 15, 2014 | 05:12 AM
eNVy997tt's Avatar
Are you referring to the led front tune signal strips or the fog lights?
Old Feb 15, 2014 | 05:48 AM
therock88's Avatar
Originally Posted by VID997
^^^therock
Hi there...
Not sure if there is something different with YOUR car, but the cheap ones in the link HERE will typically work fine. You need "Canbus - Error Free T-10 W5W" bulbs to correctly replace the oem side markers. I have used a host of these (like the ones in the link) with no issues.
On your second part. I assume you are using, or have used Durametric or PSTII or PIWIS to code the side markers to act as blinkers? When you do so, you can ONLY have one or the other....They are either on all the time (running lights), OR act as blinkers...But they will not do both.
Hope this helps.
DC
Old Feb 15, 2014 | 05:58 AM
therock88's Avatar
I took him to mean installing the 997.2 fogs (in the same spot as 997.1 fogs).
If so, they do look good and are very bright. However, my understanding is they are not plug and play, and other modifications will need to be done to avoid errors and have them work properly. Also, to change them out, the entire bumper cover has to come off..whereas what you are talking about with just changing to LED's is pretty simple...just have to cross the two wires for correct polarity.
COST for EACH 997.2 (2011) fog lamp assembly is .. $425.23 + maybe a few other small parts. Part numbers - 997-631-077-03(L), 997-631-078-03(R)
DC
Old Feb 15, 2014 | 07:35 AM
GTRNICK's Avatar
GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !GTRNICK Is a GOD !
DC
I swapped mine for the gen 2 fogs and they work fine.
Old Feb 15, 2014 | 07:44 AM
ryem3's Avatar
DC
Holy cow! $1000 mod. That's crazy. I never use them as the headlights have excellent lenses. The led mod sounds good for $60.
