GT2RS Intercoolers / Installed
Old Dec 26, 2014 | 05:03 PM
elite1's Avatar
elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !elite1 Is a GOD !
Finally finished this. I couldn't find a DIY for the 997's. The ducts are different. I modified them so the intercooler was centered, which makes sense as the bracket should centered once that is attached.
Honestly, there is a lot of work involved with this.
Old Dec 26, 2014 | 06:05 PM
therock88's Avatar
therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !therock88 Is a GOD !
Looks like you did a really nice/neat job of it! Good job. Still waiting for mine to arrive...Next Tuesday. Already have everything apart and trimmed the ridge off the air guides..I was planning on trimming out the tabs rather than using Zip Ties...Looks like that is what you did? I was hoping that would fit...Looks like it does.
Not that it is needed, but I also line the air guides with some High density PVC foam molding? Maybe will help seal them...who knows...I doubt it will hurt
Posted a pic of the molding just as an FYI.
DC
Old Dec 26, 2014 | 06:53 PM
elite1's Avatar
Hi Rock,
I didn't trim all the edges on mine. I just trimmed the ends and also trimmed the intercoolers. If you don't trim the intercoolers, you wont be able to alter the factory straps.
I also decided to seal the ends in overkill mode.
Old Dec 26, 2014 | 06:59 PM
elite1's Avatar
One more thing, I also liked leaving the metal flange from the intercooler after it was cut. This allowed me to have a nice seam between the intercooler and plastic ducts. Still allowing the outer fins to be somewhat useful.
Old Dec 26, 2014 | 07:01 PM
therock88's Avatar
Originally Posted by elite1
Hi Rock,
Thanks! Since I do not have mine yet, I cannot see how big, etc...
So I was referring to opening the holes on the bottom of the fastening tabs as opposed to Zip Ties. It looks like that is what you did in the picture is that true?
Also I was planning on trimming the air guides where the tank fastens to the core as you did...But again, waiting for mine to know where to trim Appears you trim right at the thicker tabs.
Last question for you...What did you use to seal the tanks? I assume some two part epoxy? or??
Thanks!
Also...Have yu been able to take it for a run yet? I have a feeling right after I get it back together the weather is going to crap out...and will be months before I even get to test it....I went ahead and ordered rear brake pads since it is up and open and I cannot use it....
Take care,
DC
Old Dec 26, 2014 | 07:09 PM
elite1's Avatar
I haven't started the car for over 6 weeks, which is my next issue I guess. Hopefully these photos will help you.
I can dig around for the interlip config. this is what seals the hood to the intercooler using this method. I spent 6 hours to examine this prior to cutting anything. I just have to get my hi temp silicone tomorrow to finish it out.
Old Dec 27, 2014 | 07:30 AM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
subscribed
Old Dec 27, 2014 | 11:07 AM
pwdrhound's Avatar
Could you just buy the 997.2 ducting for a plug and play set up?
Old Dec 27, 2014 | 11:25 AM
gofast's Avatar
gofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud ofgofast has much to be proud of
Yes, but the ducting is very over priced..
Old Dec 27, 2014 | 11:28 AM
elite1's Avatar
Ducting for the 997.2 should swap out fine without alteration. I believe a 6speed member has already Done this.
Old Dec 27, 2014 | 12:00 PM
therock88's Avatar
Agree with others...Seems like overkill, but if you wanted to go that route...here is what you need: ( note there is an upper and lower gasket, those are not duplicates)
5 - Part Number: 99757565701
intake duct 3.8 LITER Left
MSRP: $301.55
5 - Part Number: 99757565801
intake duct 3.8 LITER Right
MSRP: $301.55
6 - Part Number: 99757586901
intake duct gasket 3.8 LITER Left
MSRP: $34.98 $0.00 $25.58
intake duct gasket 3.8 LITER Right
MSRP: $34.98
9 - Part Number: 9975754710101C
lower duct 3.8 LITER Left
MSRP: $291.41
9 - Part Number: 9975754720101C
lower duct 3.8 LITER Right
MSRP: $291.41
10 - Part Number: 99757589000
lower duct gasket 3.8 LITER Left
MSRP: $34.98
10 -Part Number: 99757589000
lower duct gasket 3.8 LITER Right
MSRP: $34.98
You can find these cheaper, or used, but at MSRP you are looking at : $ 1328.84 + Shipping and/or tax.
DC
EDIT: Added Part Diagram and reference numbers
Old Dec 27, 2014 | 12:37 PM
elite1's Avatar
Maybe a salvage yard may be the best option.
Thanks for posting the part numbers rock. Your a champ.
Old Dec 27, 2014 | 12:47 PM
therock88's Avatar
No Problem. I added the diagram and part reference numbers to my previous post to assist as well.
DC
Old Dec 27, 2014 | 12:53 PM
saabin's Avatar
saabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond reputesaabin has a reputation beyond repute
I thought about that option and called LA dismantlers in CA.. They would only sell the intercooler with the ducting included. I don't remember the price now, but at the time I noted that it wasn't cost effective to go this route since I already had purchased the coolers themselves..
Now maybe if you were starting from scratch it might make sense..for some reason 1400 sticks in my head..pretty sure that was the price for each side.
Old Dec 27, 2014 | 01:18 PM
therock88's Avatar
Yep...They had the whole units listed for about ~ $1399.99 each side from a 2012. Dremel tool is much less
DC
