TPC's DSC quick review...
Okay Akunob a friend of mine who lives near by has a TPC module on his turbo. He is v.complimentary about it and runs similar set up to TB993tt so I will keep an open mind. I'll see if I can persuade him to install it in my car for a quick half hour test and will report back.
Good luck mate, I hope you get try it out and report back. Positive, negative or no discernible difference over stock, we'd love to hear about your experience...after all that's what the forum is for!
I just received the Tpc module this afternoon n got it installed immediately, what I can say is the car feel more firm on the ground but don't know why I lost the function of the absorber switch? Last time without the Tpc mobile it was functioning as per normal but after I install the module it no longer has the light anymore?
In general after installation the module is like the car is in sport mode cos when I'm driving in auto gear mode it will drop to 1st gear n now is happening this way so I suspect the module tap into the sport button n nothing else. How can the changing of module affect the gear change??? Or am I missing some info??? I remember seeing somewhere that mention about a few mode that I can switch to about the module? Can someone shine some lights on this? To me is too harsh to use it on the street cos is too stiff on the suspension but maybe good to be on the track.
It should only effect your shock setting. It has 3 modes. Mode 1: light is always on, Mode 2: light blinks twice, Mode 3: light blinks 3 times.
Your sport button should not be effected in anyway, other than that it no longer will turn your PASM to the firm mode.
The DSC should not affect your gear changes. Hope this helps.
If by "absorber" switch you are referring to the PASM button, then this now controls the three modes of the DSC module. If functioning properly, press the PASM button to cycle through the modes. The light sequence will indicate which mode you are in (on = 1, two blinks = 2 and three blinks = 3).
Send it back to TPC. They will get you another one. Sounds like a faulty unit.
+1 I would send it back for an exchange.
When plugging in the DSC module, it will not affect the Sport function as they are on different circuits. I have never heard of this before and there are several Tiptronic and PDK users out there, so we will be sending you a new module and will let you know of any error codes that we pull from the DSC module that you currently have.
Will wait for the replacement. Thanks
Andy
