997tt caliper piston
Old Jun 28, 2017 | 08:15 PM
jdexter's Avatar
jdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to beholdjdexter is a splendid one to behold
What's up with one of these that is loose, any help? I'm not familiar with putting these together.
Old Jun 30, 2017 | 06:35 PM
pwdrhound's Avatar
That's not a TT caliper. Appears to be a PCCB GT3 caliper which has been repainted green. The yellow insert is a Zircon heat insulator which is used on the GT3 and Cup calipers (TT calipers have 1 piece steel pistons). The zircon insulator is originally glued into the recess in the top of the piston. The glue breaks down with heat and they become loose. You can install Cup car puck retainers which tie the two together. They are sold by Porsche Motorsport for about $10 each. You will need 6 per caliper. I have them on all of mine. BTW, don't drop the zircon inserts. They are very fragile and break easily. They are not sold separately, only as part of a full caliper rebuild kit for $800 by Porsche Motorsport.
Old Jun 30, 2017 | 06:39 PM
jdexter's Avatar
I applied a bit of epoxy and glued it back on. Hope that wont be a problem.
Old Jul 6, 2017 | 03:38 PM
Johnny DB's Avatar
Do they have rebuild kits for the 997TT PCCB calipers?
Old Jul 6, 2017 | 04:04 PM
pwdrhound's Avatar
They do not. Only the the GT2/3 and Cup calipers.
Old Jul 7, 2017 | 02:00 PM
Johnny DB's Avatar
So what options would I have? Are the piston diameters different?
Old Jul 7, 2017 | 02:14 PM
pwdrhound's Avatar
They are basically throwaways unless someone makes some aftermarket replacement pistons. Don't know...
Yes, the piston diameters are different, larger on the TT calipers.
Old Jul 12, 2017 | 12:55 PM
06Turbo's Avatar
06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future06Turbo has a brilliant future
.........You can install Cup car puck retainers which tie the two together. They are sold by Porsche Motorsport for about $10 each. You will need 6 per caliper. I have them on all of mine.........
Pwdr, do you have part numbers for these? Or a downloadable PDF of the Cup car parts catalog? I have the GT3 RSR catalog but the pucks are not listed.
Old Jul 12, 2017 | 02:28 PM
Johnny DB's Avatar
That ****ing blows. Seriously, throwaway calipers...
Old Jul 12, 2017 | 02:29 PM
Johnny DB's Avatar
Originally Posted by 32krazy!
measure the diameter of the pistons and reach out to zeckhausenracing.com brembo and stoptech use the same pistons. repalce them with non ceramic pistons
Why non ceramic? I thought the Porsche 6 piston with ceramic was what everyone wanted?
Old Jul 12, 2017 | 02:47 PM
32krazy!'s Avatar
basically the ceramic pucks arent available and the steel ones are
Old Jul 12, 2017 | 11:47 PM
pwdrhound's Avatar
Originally Posted by 06turbo
pwdr, do you have part numbers for these? Or a downloadable pdf of the cup car parts catalog? I have the gt3 rsr catalog but the pucks are not listed.
997.352.086.91
Name:	PMNA puck inserts.jpg
