'Safely' Removing Under Door Pocket Lid
Old Oct 22, 2009 | 03:55 PM
dallascajun's Avatar
dallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant futuredallascajun has a brilliant future
I just received a new set of Carbon Fiber Under Door Pocket Lids and am having trouble removing the original parts. There are clips at either end of the piece that need to be popped out, but apparently the middle section is glued to the inside material of the storage box. Does anyone have any suggestions or best practices for getting this piece removed?
I have the plastic interior install tools, but am struggling to get the clips popped out, much less the glued section.
Old Oct 22, 2009 | 04:25 PM
Cattman's Avatar
Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !Cattman Is a GOD !
Don't you have to taeke the door panel off? Gundo has a DIY here somehwhere, as well as on renntech, if you search for it. If, in fact you do have to take the door panel off, it's time consuming, but if you're handy and have the right tools, it's totally doable. I may be doing this soon myself as I continue to "de-rattle" my car.
CATTMAN
Old Oct 22, 2009 | 05:09 PM
CATTMAN
No need to remove the door panel, all of the connecting pieces are accessible from the 'outside'. Just looking for a good process to remove the piece and cut from the glued section with minimal effect on the car.
I may end up seeing if the dealer can do it...I have a follow-up to some maintenance scheduled.
Old Oct 23, 2009 | 10:59 PM
TooSixy's Avatar
TooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant futureTooSixy has a brilliant future
Those pieces are nice!
Old Dec 13, 2016 | 01:05 PM
Pcar416's Avatar
Pcar416 is infamous around these partsPcar416 is infamous around these parts
Has anyone figure out how to remove these? thx
Name:	File_000 (28).jpeg
Old Dec 13, 2016 | 08:54 PM
TypeRx's Avatar
TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !TypeRx Is a GOD !
It requires door panel removal. That's the way to do it safely
Old Dec 13, 2016 | 10:44 PM
Pcar416's Avatar
doors are removed but it makes no difference
Old Dec 14, 2016 | 03:47 PM
TypeRx's Avatar
Sorry, I misunderstood and thought you were trying to remove the door armrests...duh. The trim piece you are referring to cannot be easily removed. It isnt secured by any screws or plastic rivets - I think there is a strong adhesive that holds it in place. In your case I'd mask everything up and use a flat black spray paint (or if you can find a suitable dye, perfect) on that piece when the door panel is out of the car. I believe that if you try to remove that trim piece you will end up destroying it in the process.
Old Dec 14, 2016 | 04:55 PM
Pcar416's Avatar
I decided to use some nail polish remover to scrap the soft paint off. It was hard and time consuming. can anyone recommend a better solvent to remove the paint? still have the passenger side to tackle.
Name:	File_000 (30).jpeg
ID:	465994   Click image for larger version
Name:	File_001 (13).jpeg
DLF
Cayenne 955/957
10
Feb 28, 2022 11:49 PM
NIKAS
Aug 20, 2019 07:53 PM
bzimpfer
Sep 26, 2015 10:55 PM
simoncpw
Sep 8, 2015 10:55 PM
AM v12v
Sep 4, 2015 02:52 AM
