2nd gear problem !?
Old Apr 18, 2010 | 08:04 PM
TrackAddict997's Avatar
TrackAddict997 is a jewel in the roughTrackAddict997 is a jewel in the roughTrackAddict997 is a jewel in the rough
Question 2nd gear problem !?
Well for the first time tonight my car is making almost like a little scratch noise when i go to shift into second gear Its like the sound if you do a miss shift but im shifting the car perfectly..it seems to only be happening now when i accelerate quickly. weird.. anyone know what could be happening??? i hope nothing is wrong with the car
Old Apr 18, 2010 | 08:19 PM
adias's Avatar
adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !adias Is a GOD !
Bad clutch? shot synchro?
Old Apr 18, 2010 | 08:23 PM
could it be the clutch ? everything feels fine in the other gears even sometimes when i shift into second :-/.. i have 24,000 miles on the car.
Old Apr 19, 2010 | 01:52 AM
solidst8's Avatar
solidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud ofsolidst8 has much to be proud of
Sounds like a synchro. A previous car had the same symptoms going from 2-3, changing the gear oil made it a little better but did not cure it. It only did that at high rpm shifts.
Old Apr 19, 2010 | 06:21 AM
geestyleed's Avatar
geestyleed is infamous around these parts
Same problem here. Have 23.000 meiles.
Happens often when the car stand for more than a week. But I tested car of my boss which stand like 6 weeks and this was fine.
In my car it occurs more often when I take a turn e.g. at a intersection and shift while turning (10-18 mph). But also while normal acceleration.
The gearbox even block sometimes the first gear - I have to shift in another gear until it works.
I already drove to Porsche and they couldnt find anything.
This drives me nuts. I drove 20 meiles having the problem like 6-9 times and at the dealership everything was "fine"....
Old Apr 19, 2010 | 07:11 AM
What do you think we should do?? i was going to go up to porsche today to see if they could find the problem. its horrible because if i try to accelerate fast off the line i cant shift to second without this happening therefore making me miss second.
Old Apr 19, 2010 | 07:21 AM
Fahrer's Avatar
Fahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to all
Are you sure you have the clutch pedal fully depressed and in time before shifting. Sometimes we can a get lazy with this if not careful.
Old Apr 19, 2010 | 07:24 AM
yeah definitely, i tried it like 10 times at least and it is still doing the same thing.
Old Apr 19, 2010 | 07:47 AM
DaveHutchinson's Avatar
DaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond reputeDaveHutchinson has a reputation beyond repute
Does sound like a synchro to me, have it looked at by the dealer. If it's anything like my 911 though, the second I get near a dealer, it starts to behave perfectly.
Old Apr 19, 2010 | 08:22 AM
wolfnards's Avatar
wolfnards has a spectacular aura aboutwolfnards has a spectacular aura about
that happens to my car when it's cold. it's annoying. is this happening all the time?
Old Apr 19, 2010 | 08:26 AM
geestyleed's Avatar
Same here.
It happens more often when it is cold, but also when it is kind of warm
And I definitely pressed the clutch. I made some tests on the company's parking lot and it happened several times.
If my gearbox explodes into thousand pieces, it is not my fault....I have a documentation that they didnt found anything.
Old Apr 19, 2010 | 09:44 AM
Same here.
Well i just got back from the dealer and yes on the way there it didnt happen once. but once i got the mechanic in the car and took off it happened 1st try! lol anyway he said right away its a bad synchro. so im bringing it back tomorrow for them to take it apart and look at it. they said it is possible that it will be covered under warranty so im hoping it is. If not does anyone have any idea what this might cost to fix??
Old Apr 19, 2010 | 10:02 AM
geestyleed's Avatar
If this is not covered by warranty, than the warranty is completely worthless.
When I got my car back from the dealership on a Monday, everything was kind of fine. I put in the garage until Thursday and she did it again.
I have the feeling that my 911 is comparable with a *****y women - dont drive me I have headache
Old Apr 19, 2010 | 10:53 AM
and as for the warranty i agree. it should definitely be covered because i know i haven't done anything to cause this damage.
PV=nRT.
Sep 9, 2022 06:06 PM
jaehoppa
Oct 22, 2015 09:17 PM
georgemaser
Oct 17, 2015 05:59 PM
proTUNING Freaks
Sep 15, 2015 07:28 AM
GSP
Sep 9, 2015 05:31 AM
