Worn fan switch - repaint? replace?
Old Aug 20, 2010 | 11:36 PM
csm356's Avatar
csm356 is infamous around these parts
My new-to-me '05 is near perfect (just 35k mi.) except for some fairly inexplicable wear on the fan control. Is this a common wear point? Can it be touched-up, or must I get a new rocker? If I do replace, will it wear again like this? The temp control is showing a little of the same, so...? Is this a common high-wear item? My Audi at 10yrs and 200k miles doesn't show anything like this except for maybe the top of the shifter ****.
Old Aug 21, 2010 | 06:00 AM
thor7000's Avatar
thor7000 is infamous around these parts
I also have an 05 and everything still looks like new, but I did check out some cars prior to mine that did have that problem. Can't understand what people are doing to rub them down like that...personally, I would replace them...it would drive me nuts if mine were like that!!
Old Aug 21, 2010 | 06:29 AM
slant83's Avatar
slant83 has a spectacular aura aboutslant83 has a spectacular aura aboutslant83 has a spectacular aura about
Common wear item on Porsche with the rubberized soft touch controls. You'll be unable to replace the toggle without replacing the entire unit (according to Champion Porsche)
My 05 Carrera still is ok (but the rubber is softening and perhaps about to go...I suspect the summer heat "liquefies" the rubberized material). On my 05 Boxster with triple the miles...not even a rubmark..go figure
Old Aug 21, 2010 | 06:59 AM
machina's Avatar
machina has a spectacular aura aboutmachina has a spectacular aura about
Mine was replaced under warranty.
The new unit has buttons that are plastic only instead of the rubber coating, guess they learned their lesson with that one.
dr
Old Aug 21, 2010 | 08:13 AM
Fahrer's Avatar
Fahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to allFahrer is a name known to all
This can happen with any car that has painted interior surfaces. Generally black parts use black plastic rather than paint but as a result of low production numbers ( possible with Porsche) often the parts are moled in natural color and painted for each interior. Also parts will often be painted so they match better.
The only solution to minimize the risk or peeling paint is to make sure one's hands are clean make sure there is no sun screen, oil or hand cream on your hands. Stuff like that will destroy paint in no time.
Old Aug 21, 2010 | 08:21 AM
NorthVan's Avatar
A lot of manufacturers (VW, Porsche; Audi) tried these soft touch rubberized buttons and they would wear if you used a lot of hand cream. My Touareg was driven by my wife before, and she ended up with the NAV and HVAC unit being replaced under warranty.
The only way to repair it is to replace it, you can also try the matte black model paints (Testor) and that has worked for some others in the past.
Old Aug 21, 2010 | 06:16 PM
surfah's Avatar
surfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond reputesurfah has a reputation beyond repute
dr
My 07 C2S only has 11K on the clock and both temperature and fan buttons showed significant wear. I tried using permanent marker to touch up the areas where the black paint had come off but that was a futile exercise
Ended up getting both replaced under warranty 2 wks ago when I had my 3 year service. Apparently, if one has to pay out of pocket, the cost is quite exorbitant because the entire center console must be removed.
FWIW, the passenger air bag warning light also had a small crack which was replaced under warranty.
Old Aug 21, 2010 | 06:24 PM
bbywu's Avatar
It's about $500-600 for the replacement console.
For an 05, with heated seats, the part number is 997 653 111 09
For an 05 without heated seats, the number is 997 653 101 09
Old Aug 21, 2010 | 09:10 PM
csm356's Avatar
Thanks for the input. I'll have the 45k coming up, I have CPO (kinda surprised it wasn't addressed then by the dealer) and I'm going to add a Denison or Mo-Porsche-40 (TBD), so while the console is apart....
Old Jul 27, 2012 | 06:36 PM
GordieHM's Avatar
GordieHM is infamous around these parts
Color it with a black permanent marker. Better than buying a new unit and
lasts for a long time.
Old Jul 27, 2012 | 08:15 PM
AP 997S's Avatar
AP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud ofAP 997S has much to be proud of
Old Jul 27, 2012 | 09:55 PM
Gpjli's Avatar
Gpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud ofGpjli has much to be proud of
My solution also. I can live with it that way.
Old Nov 25, 2013 | 04:08 AM
flatsixrocks's Avatar
flatsixrocks is infamous around these parts
I recently found a solution for this issue. Itīs called ClimaRepair, itīs a complete kit, takes 10 minutes and you can do it yourself. Itīs sold at climarepair.com
Have a picture of my car with the kit installed (before and after):
cheers!
ID:	305405   Click image for larger version
ID:	305406   Click image for larger version
Old Nov 25, 2013 | 03:12 PM
And at night (just took them)
Lights on
Lights off
ID:	305651   Click image for larger version
Old Nov 25, 2013 | 05:14 PM
AreaOne's Avatar
AreaOne has a spectacular aura aboutAreaOne has a spectacular aura about
Did you take the buttons out to repair them?
