997.2 LED Interior Lights
Old Sep 11, 2012 | 08:04 PM
  #91
sirschwag's Avatar
sirschwag is infamous around these parts
Has anyone successfully removed just the lens of the dome/map light to replace the bulbs w/LED's? If so any tips? Or is it easier/safer (less risk of breaking the lens) to just remove the entire overhead cluster to do this? Thanks!
Old Feb 18, 2013 | 06:17 AM
  #92
dr_ashk's Avatar
dr_ashk is infamous around these parts
Originally Posted by frontside720
Yes.
I have tried every housing in all three locations and it's just the passenger footwell that doesn't work with the LED bulb. Works with the regular bulb but not the led.
I ordered new bulbs and they should be here soon so hopefully a different type of bulb will do the trick.
It really makes no sense at all to me. I know the wires and the housing work because my old bulb still works.
hello
i got the same probleme as you for passenger foot light
i spent more than 2 hours trying to find the problem but no clue
did you find a solution for this strange & stupid probleme?
did you find
Old Feb 18, 2013 | 06:19 AM
  #93
dr_ashk's Avatar
for me i brook the lens
so i think its much safer to remove the entire overhead cluster... but how? i really don't know
Old Feb 18, 2013 | 06:42 AM
  #94
Domer911's Avatar
Domer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond reputeDomer911 has a reputation beyond repute
The lens is all you have to remove. It is easy. I can't find it right now, but somewhere I found a DIY. It may include removing parts from the dome light cover, but again, this is easy to do without breaking anything. I should know, I usually do break something, but just not in this case.
PS-There's a very clear picture of the removed lens on page 4 of this thread!
Old Feb 18, 2013 | 08:06 AM
  #95
Domer911's Avatar
Here's the link to a Youtube video that is helpful for the dome lens.
Old Feb 18, 2013 | 08:03 PM
  #96
plantagenet's Avatar
plantagenet is infamous around these parts
It has to be the tool he has because I have tried that and it doesn't want to drop
Old Feb 21, 2013 | 06:07 AM
  #97
jhbrennan's Avatar
http://www.youtube.com/watch?v=UBtqqQjmfjo
Domer - thanks for this link. Since you've done this LED change where did you run into problems or is the swap as straight forward as it looks? Thanks.
Old Feb 21, 2013 | 06:09 AM
  #98
jhbrennan's Avatar
Originally Posted by dr_ashk
hello
did you find
Did you flip the bulb to change the polarity. I think he mentions that in the install video.
Old Feb 25, 2013 | 04:05 PM
  #99
cam99's Avatar
cam99 is infamous around these partscam99 is infamous around these parts
I used two screw drivers to help compress the spring clips in AND then I used my fingers to pry out the hole housing.
Old Jul 24, 2013 | 11:28 AM
  #100
MMK110464's Avatar
MMK110464 is infamous around these parts
Updated links to vleds
I stumble upon this thread while researching on led conversions for the 997.2.
The list of the leds needed was very helpful but the links were broken.
I pmed Arrerac911 and he was kind enough to send me the updated links (he deserves any rep points for this post). Here is the updated list:
Courtesy lights: RED T10 5 LED light bulb,
http://www.vleds.com/bulb/194-168-15...25-1-pair.html
Dome/Map lights: 1x 5K WHITE 42mm festoon 4 LED high power bulb, 2x 5K WHITE T10 2W high power bulb
http://www.vleds.com/bulb/211-42mm-l...djustable.html
http://www.vleds.com/5k-white-4-led-...58-1-pair.html
Footwell and Glove box lights: 5K WHITE T10 194 4 LED 2W flank style bulb,
http://www.vleds.com/bulb/194-168-15...58-1-pair.html
Engine compartment and Frunk: 5K WHITE 42mm festoon 4 LED high power bulb
Old Jul 24, 2013 | 08:43 PM
  #101
ryem3's Avatar
ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !ryem3 Is a GOD !
Great idea, but no points yet - alll of these links are still toast. Thanks.
Old Jul 24, 2013 | 10:05 PM
  #102
MMK110464's Avatar
Fixed!
Old Sep 28, 2015 | 01:22 PM
  #103
997 Turbo's Avatar
997 Turbo is infamous around these parts
I want LEDs also in the "make-up mirror" lamps, anyone?
I mean sun visors bulbs.
http://www.911uk.com/viewtopic.php?t=69205&highlight=
COBB Tuning
Jan 1, 2025 09:02 AM
pnoob2
Oct 31, 2015 06:34 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
