WOW! ROTtec 997.1 DRL LED's
Old Dec 16, 2011 | 12:10 PM
  #106
coco0045's Avatar
coco0045 is infamous around these parts
Installation Video
The DRLs looks absolutely amazing! Thanks Ray. Will begin testing them later. Fingers cross..hopefully no error codes. In the meantime, I had a little trouble figuring out how the heck to install the DRL but after some reading it was too simple. Anyhow, I made a short video on how to do it. Hope this helps.
Old Dec 16, 2011 | 12:39 PM
  #107
Ray's Avatar
Ray
Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !Ray Is a GOD !
Thanks or the video! Yes, this should be a easy fix and I've arranged a local car for testing this weekend.
Old Dec 16, 2011 | 01:33 PM
  #108
v35's Avatar
v35
v35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond reputev35 has a reputation beyond repute
The only time I ever get the "Right side light error" is after driving the car on the freeway for about an hour and hit a good amount of bumps. It usually comes on if I hit a really big bump which leads me to believe a loose connection to a resistor somewhere. The error never shows up if the car is idle or when I drive on side streets.
Old Dec 16, 2011 | 03:52 PM
  #109
DirtyVegas's Avatar
DirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud ofDirtyVegas has much to be proud of
I get that msg the minute I start my car.
These error messages seem to be caused by variety of R/L lights inside the DRL, and also at different times during different conditions. Makes me wonder if this is just poor assembly all together, as there errors and issues are all across the board. Hope that I'm wrong and that there is a simple fix for this in the works, but I see having to take these out for replacement when it becomes available.
To get the new DRLs out, simply pry them out with something while the card is inserted and they will pop out with just a big more effort than OE. No big deal, just don't scratch the paint.
Old Dec 16, 2011 | 06:03 PM
  #110
coco0045's Avatar
So far so good...no error codes! I'm just a bit curious, when the headlights and DRL comes on, the middle light row is lightly lit right? I thought that it would be brighter. However, when I use the headlights along with the fog lights then the third row led is very bright. So I guess my questions is when the headlights are on normally along with the DRL, the middle row led is alot dimmer than the third led row right? I just wanted to make sure this is normal. Thanks!
Old Dec 16, 2011 | 06:14 PM
  #111
keninirvine's Avatar
keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !keninirvine Is a GOD !
The middle light is a parking light, which is always less bright than a fog light or DRL. Just look at the low level of light from the normal parking light, compared to the normal fog light.
Old Dec 16, 2011 | 10:34 PM
  #112
tlis300's Avatar
tlis300 has a spectacular aura abouttlis300 has a spectacular aura about
I just installed my DRL and its getting a error message to check the right light. YIKES!
Old Dec 16, 2011 | 11:07 PM
  #113
tlis300's Avatar
Hey guys, if you are having trouble getting the Rottec DRL light out, trying using two cards. Insert the OEM card that came with the car and then insert another card similar in size (a flimsy will not work). By doing so, the light will pop out. I had an old Direct TV card I used and it popped out. Hope that helps.
Old Dec 17, 2011 | 12:45 AM
  #114
808c2s's Avatar
808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !808c2s Is a GOD !
Good tip. Thanks.
Old Dec 17, 2011 | 01:08 AM
  #115
sideWays_swe's Avatar
sideWays_swe is a jewel in the roughsideWays_swe is a jewel in the roughsideWays_swe is a jewel in the rough
Where is this card located? I couldnt fond one in my car. Had to make my own.
Old Dec 17, 2011 | 01:43 AM
  #116
808c2s's Avatar
It's included in your Owner's Manual Booklet Holder. If you bought your car used, then it may not be there anymore.
Old Dec 17, 2011 | 05:42 PM
  #117
coco0045's Avatar
Thanks! Hopefully will not need to remove lights anytime soon
Old Dec 17, 2011 | 10:39 PM
  #118
ELUSIVE's Avatar
ELUSIVE is infamous around these partsELUSIVE is infamous around these parts
Has anyone else that installed the Dectane DRL module tried to hook up their car to a battery charger like in this thread?
https://www.6speedonline.com/forums/...y-charger.html
Old Dec 18, 2011 | 12:29 AM
  #119
Ray's Avatar
Ray
We have positive result of testing today and found out a easy way to turn off front left or right light warning. I will contact anyone who had email me with this warning light issue shortly for solution!
Old Dec 18, 2011 | 01:10 AM
  #120
NJM500's Avatar
NJM500 is infamous around these parts
Thanks Ray. Look forward to hearing the solution.
