Battery Tender or Disconnect Battery?
Old Jul 31, 2012 | 11:03 AM
bchow83's Avatar
bchow83 is infamous around these parts
I am going out of town for about half a year and was wondering what you guys recommend as storage options. Do I go with a Battery Tender or is it just ok to disconnect the negative. Any recommendations for Battery Tender? Thank you.
Old Jul 31, 2012 | 12:53 PM
IslandS62's Avatar
IslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of lightIslandS62 is a glorious beacon of light
I use a CTEK, which can be had for under $50. A battery that just sits will degrade and die, but a tender will run charging programs to keep it in top condition.
Old Jul 31, 2012 | 12:56 PM
White Rock's Avatar
White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !White Rock Is a GOD !
I use the dual mode Porsche battery tender and have no issues in more than a years worth of use. Bought it from Suncoast (board sponsor). It's currently on sale for $105.00
http://www.suncoastparts.com/product//95504490054.html
Old Jul 31, 2012 | 01:06 PM
MBENZF1's Avatar
MBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud ofMBENZF1 has much to be proud of
I disconnect my battery over the Winter months. Get a PSM failure when I start the car, but that goes away within a mile and it's never bothered me.
Old Jul 31, 2012 | 01:17 PM
Arnie55's Avatar
Arnie55 is infamous around these parts
I use a Battery tender and have had no issues. I also use the battery tender in the summer months when I'm not driving the 911
Old Jul 31, 2012 | 03:38 PM
djantlive's Avatar
a battery tender will be better for the battery. batteries lasts longer when stayed charged. you can disconnect the battery also if needed. Disnconnecting the battery is fine though, especially if the car isn't near a power outlet.
You should also over inflate your tires, especially the rears, to avoid flat spotting. The owner manual covers that. Also, fill up the gas tank and put a few drops of stabilizer if you want to be extra safe.
Old Aug 6, 2012 | 04:04 PM
bchow83's Avatar
Thanks guys.
Old Aug 6, 2012 | 04:08 PM
MI55LE's Avatar
MI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to beholdMI55LE is a splendid one to behold
I volunteer to drive it while you're gone - that'll keep that pesky battery from dying (or, use a battery tender)
Old Aug 7, 2012 | 09:23 PM
devil boy's Avatar
devil boy is infamous around these parts
I'm away on extended business travel too and my car sits in a storage unit with no power outlets. I disconnect my battery (and I prop the hood with a towel so it doesn't latch). Last time I was home it started up just fine after reconnecting the battery and I got the usual dash alerts that went away once I started driving.
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
WheelsupZR1
Oct 20, 2015 08:36 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
gliozzi
Bentley
Sep 28, 2015 03:27 PM
