How hard is it to replace starter cable?
Old Mar 12, 2014 | 06:20 PM
pvanosta's Avatar
pvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nice
Great thread.
My '06 C2S is getting lazy starts when warm as well (on a relatively new battery), so I'm seeing this job in my near future.
Can someone please list the part # and where you sourced it?
Thanks very much!
Old Mar 13, 2014 | 12:26 AM
GETU1's Avatar
GETU1 is infamous around these partsGETU1 is infamous around these parts
Wow, $350 is CHEAP!
Old Mar 13, 2014 | 09:06 AM
devil boy's Avatar
devil boy is infamous around these parts
Presently $99 at Suncoast.
http://www.suncoastparts.com/product...ra_S_Engineexl
It's a little more at Pelican but you'd have to compare shipping costs because Pelican may offer free shipping.
Pelican Parts
Old Mar 13, 2014 | 09:24 AM
pvanosta's Avatar
Thanks Devil Boy.
Old Mar 13, 2014 | 07:23 PM
Cali_997's Avatar
Cali_997 is infamous around these parts
Pelican Parts
Thank you~!!
Old Apr 21, 2014 | 11:51 PM
devil boy's Avatar
I replaced my starter/alternator cable last weekend. What a *****! Those clips that secure the cable to its feed tray are tricky. I found it better to just cut the old clips and work at removing them after the cable is yanked out. The new cable comes with its own clips. I would put this DIY at 9/10 for difficulty although now that I know what to expect maybe I could downgrade it to an 8/10.
Old Apr 23, 2014 | 06:28 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Originally Posted by thekubiaks
My indy recommended that I go ahead and replace the starter while he had it off, it wasn't making any weird sounds but he said he had seen enough of them that it would be recommended, so I did. My Porsche buddies swear that he is a straight up guy.
Starter = $300
Cable - $125
Labor - $225
Total - $650...would have been $350 without a new starter.
No need to remove the starter when replacing the harness as it doesn't interfere with access to the harness in any way. Job is 3 hours tops for someone whose done it before with a lift to improve access to the harness from under the car.
Old Apr 23, 2014 | 11:11 PM
devil boy's Avatar
You know what? The new cable didn't improve my slow hot starts. Doh!! I'm wondering if it's just a weak starter now. I'm going to double check my engine to chassis grounds this weekend. If I'm lucky it will be that. I really don't want to tear all that stuff off again to get to the starter. You know that feeling of doing all that hard work for nothing...yeah it's like that.
Old Apr 24, 2014 | 01:28 PM
Minok's Avatar
Minok has a spectacular aura aboutMinok has a spectacular aura about
One theory on wiring fixes is to try running wiring external to the system just to test, "Is this wiring the solution", before one installs the wiring in the wall/car. So I wonder if one can run a parallel external heavy-guage wire solution to provide a run for the battery to the starter, or starter to chassis, to test if those wiring points solve it, and if they don't then its gotta be the battery or the starter, yes?
Old Apr 24, 2014 | 04:11 PM
devil boy's Avatar
That's what I'm going to attempt to do with the ground wires although getting to the starter ground will be a challenge.
Old Apr 25, 2014 | 09:11 AM
Dadio's Avatar
Be sure and update us on the outcome of this approach.
Old Apr 25, 2014 | 10:24 AM
devil boy's Avatar
I checked all my grounds and I have good continuity everywhere with 0 ohms resistance between the starter/engine/chassis etc. I went ahead and cleaned all the leads on the starter with a wire brush anyway. I'm trying out some heat shield wrap around the starter to see if that helps a bit. I posted up a pic in the starter thread.
The_Ruski_Driver
Oct 25, 2015 08:40 PM
orbelo
Aug 30, 2015 12:26 PM
Zero911
Aug 24, 2015 06:51 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
