TPM (Tyre-Pressure Monitoring) issues?
Old Aug 7, 2006 | 04:19 AM
mishref's Avatar
mishref is infamous around these parts
The TPM on my car is giving me weird errors today. As soon as I started the car it said that front right tire needed air because it lost 4psi. I checked the tire, everything seemed fine and I would fill it up after work. As soon as I got to work; It said that the rear right tire was flat (lost 7 psi). So I parked it and checked the tire; everything was fine. I then reset the TPM system, it relearned the PSI and everything seemed fine (41psi rear - 34psi front on both left and right).
Old Aug 8, 2006 | 05:02 AM
03-turbo911's Avatar
Senior Member
I didn't have an issue with it untill I started playing around with different pressures.
Old Aug 8, 2006 | 11:42 AM
damon@tirerack's Avatar
Moderator
I firmly believe that some days these thigs have a mind of their own. Great idea, they just need to get a little more accurate. Mine will flash on the dash some days when I get into it and just go away after awhile - no explanation.
Have the dealership run a test on them to make sure your receiver is working correctly.
damon@tirerack.com
877-522-8473 ext. 4643
574-287-2345 ext. 4643
Or use this link:
Old Aug 10, 2006 | 06:32 PM
emilgh's Avatar
emilgh is infamous around these partsemilgh is infamous around these parts
Same deal here. Great idea, still a tad twitchy.
I've got the same setup in an Audi A8L, which also has issues from time to time.
Old Aug 12, 2006 | 05:47 AM
Senior Member
You can turn-off the TPMS in the Audi but yo can't in the Porsche.
Old Aug 15, 2006 | 10:13 AM
chrnec's Avatar
chrnec is infamous around these parts
tpms
mine consistantly reads low by 2 lbs (all 4 tires) used several quality guages and digital all say the pressures are higher than shown by 2lbs. club coupe seems very sensitive to tire pressures so now i use tpms at 2 lbs lower than recc.
Old Aug 15, 2006 | 12:48 PM
mishref's Avatar
Mine is still having erratic issues. It is listing the front two tires as having -4psi. After I reset it, it started displaying that the rear tire was -4psi ... Dropping it off for the oil change soon, they can take a look at it.
Old Aug 4, 2011 | 11:01 PM
rye595's Avatar
rye595 is a jewel in the roughrye595 is a jewel in the roughrye595 is a jewel in the roughrye595 is a jewel in the rough
Reviving an old post because I'm having this exact same problem. If you're still around, what was the resolution?
Old Aug 5, 2011 | 02:38 AM
beaboarder's Avatar
beaboarder is infamous around these parts
I was having the same issues the last couple of days. Everytime I would get in the car and start up I would get a -4 psi error code. I would reset the system and everything would be fine until the next start up, then a different wheel would show -4psi error. I finally inflated each tire about 4-5 psi over my normal tire pressure ( I run 34 frt, 40 rear) then let some air out to my normal running pressures, reset the system and everything has been fine for the last week ( I am a daily driver) or so. This procedure seems to work for me anytime my tps starts acting up.
Old Aug 5, 2011 | 07:00 AM
rye595's Avatar
Interesting... that's exactly what mine is doing. Only on startup, but then of course it persists until you reset it. I've had the battery disconnected a lot lately, working on a stereo project. I was wondering if the computer got pissed at me I'll try changing tire pressures and see what happens.
Old Aug 5, 2011 | 03:15 PM
Dadio's Avatar
Dadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond reputeDadio has a reputation beyond repute
Had a similar issue on the front left the other day. Showed 4 pounds light. Checked with an accurate gauge and got a cold reading of 33. Added 4 pounds and got a reading of 37 pounds from the system again with the tires cold. Lowered pressure 4 pounds and got a reading of 34 cold and haven't had any issues since. First time it has happened since I got the car. Battery could be low in that sensor but going to wait and see before I have it checked.
adnanm3
Nov 22, 2023 02:43 AM
PV=nRT.
Sep 9, 2022 06:06 PM
Paintballzen
Oct 10, 2020 12:22 PM
Rguy
Apr 12, 2020 11:11 PM
WheelB
991 Turbo Vendor Classifieds
Jul 23, 2018 09:37 PM
