How to change DB9 speedometer from kilos to miles?
Old Jan 8, 2011 | 08:44 PM
jmorod's Avatar
jmorod is infamous around these parts
Battery died and when finally restarted, the speedo (not the odometer) changed from mph to kmh. Can this be changed back easily?
Old Jan 9, 2011 | 12:16 PM
MichaelD's Avatar
MichaelD is infamous around these parts
Maybe its still mph and you're just driving much faster now
Old Jan 9, 2011 | 01:17 PM
jmorod's Avatar
That's exactly what I thought!! I looked down when I was on the freeway and was shocked by how fast the flow of traffic was.
Old Jan 10, 2011 | 04:31 PM
MichaelD's Avatar
Notice that nobody has come up with an answer, it might be worth you trying on PistonHeads, http://www.pistonheads.com/gassing/f...f=70&mid=17856
Rick runs an independent in UK and is very knowledgeable and very helpful, if he sees your post I'm sure he will try to help
Old Jan 12, 2011 | 10:51 PM
gekko's Avatar
gekko is infamous around these partsgekko is infamous around these parts
The digital readout in the tacho can be altered very easily:
Press & hold the "Read" button & the left stalk button simultaneously to flip between km to miles.
Hope that's what your after.
Cheers
Old Jan 13, 2011 | 08:27 AM
jmorod's Avatar
That was easy! Thanks for your help...I really appreciate it.
Old Nov 25, 2018 | 06:27 AM
A007's Avatar
A007 is infamous around these parts
Correct information
If you hold the ‘Read’ button and press the end of the left hand stalk at the same time holding for a few seconds it will change to MPH.
Old Nov 26, 2018 | 04:47 AM
handyman2009's Avatar
Veteran: Canadian Forces
This info is also found in the Manual that came with the car.
COBB Tuning
Jan 1, 2025 09:02 AM
DonBond
Apr 16, 2016 07:55 PM
SharkyShark20
Sep 19, 2015 09:54 PM
gulf gt
Aug 27, 2015 10:27 AM
00aston
Aug 27, 2015 12:01 AM
