Drove the Vantage S ... I have changed my mind
Old 08-30-2013, 03:38 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Originally Posted by 007 Vantage
From what I am hearing AS,3 is worlds better than 1&2, but until I test drive its hard to confirm that. I realized the best plan may be to get the 09 4.7 vantage 6speed for now until the V12 Vantage S takes a huge hit in depreciation, then just pick one up in a couple years. Perhaps I will like the V12S more than I did the standard V12, which for some reason didn't do it for me.
ASM3 is ASM2 with revised ratios, reinstatement of the oil cooler from ASM1 and minor tweaks to the ECU. Its not a quantum leap forward but an improvement. It retains the D "issue"
ATEOD it is a robotic manual with a clutch and not a "slush" box with torque converter
I used to lift slightly in my ASM1 car on up shifts, continued when I went to ASM2 but soon found there was no point, it also benefits from being left in Sport mode as well (other than round town)
The SP10 reverts to the manual box used from day 1 of the Vantage with the stupidly high reverse gear.
Old 08-30-2013, 04:55 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Stupidly high reverse gear haha ... So true. I wish they swapped reverse gear ratio with 1st gear
Old 08-30-2013, 04:58 PM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
So the newer transmissions still have the same gearing for reverse? This another one of those issues I've never experienced. Then again, I haven't done a lot of uphill reversing.
Old 09-01-2013, 02:42 PM
mikey k's Avatar
Only the manuals ASM2 reverse is closer to first
COBB Tuning
01-29-2022 09:42 AM
Tremelune
10-22-2019 06:12 PM
DaveG
10-01-2015 01:02 PM
terminal_ac
09-12-2015 03:26 PM
00aston
08-27-2015 12:01 AM
Quick Reply: Drove the Vantage S ... I have changed my mind
