loud cluncking noise when going to a stop first gear...normal?
Old Nov 23, 2013 | 06:39 PM
VSKCHOI's Avatar
VSKCHOI is infamous around these parts
hey guys.
parked the car..07 vantage for about 2 weeks...drove it today...and I noticed when I m coming to a stop...sport shift...to first gear ..I heard a loud clunking noise ...sounds like something fell down from the bottom...its kind of loud....and happened a few times today..only happens when I'm coming to a stop in first gear..
is this something I have to worry about?
Old Nov 27, 2013 | 08:38 AM
VSKCHOI's Avatar
hi guys
just to be more specific...it has the metal clanking noise when im going slow speed at a parking lot. sometimes on turns
It sounded like I had just run over a metal garbage can lid, though, which freaked me out to the point I got out of the car to see if I had either dropped a part of the engine on the ground or I had, indeed driven over a metal garbage can lid.
Old Nov 27, 2013 | 08:56 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Something like this happens with mine occasionally (once or twice a year) -- I always chalk it up to gravel caught in the front brake shields. Usually on low speed turns, but not always. I agree, sometimes it sounds like metal parts have fallen out on the ground.
Old Nov 27, 2013 | 11:53 AM
VSKCHOI's Avatar
the sound makes me worried because it is pretty significant
Old Nov 27, 2013 | 11:55 AM
VSKCHOI's Avatar
happens at low speed as well, usually 1st gear..
it happens once every other day...its winter here, i dirve it when its not snowing...todays temp is around -4-0..
i wonder if it is due to cold?
Old Nov 27, 2013 | 11:56 AM
VSKCHOI's Avatar
when its cold, i hear all kinds of weird noises LOL
Old Nov 27, 2013 | 03:29 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Cold = noises I discovered
It's clear skys and still no snow in Minneapolis, so until it snows I will keep driving the Vantage. My 07 manual shift did not seem to make as many 'noises' as my 09 sportshift, but if I park it outside and not in my heated garages, it makes all sorts of complaining noises, just like the garbage can lid clanging noises you described... gets progressively worse as the temperature drops closer to zero degrees F. Another thing is the tires do not like cold pavement at all. If my car could talk, it would tell me that it had a great life in sunny California for 4 years, and must have lived an evil past life to be sent to the frigid north, so I think the sounds are the cars way of telling you something that is not allowed to repeat on this blog.
Old Nov 27, 2013 | 04:00 PM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Are you sure your parking brake is disengaged fully? They can get a bit sticky....
Summer tires are not designed to operate below 35 degrees, they will get hard and lose their grip. You need to change to an all season tire at the very least.
Old Nov 27, 2013 | 10:51 PM
frankgtb's Avatar
frankgtb is infamous around these parts
try going to a stop in neutral just to eliminate brakes, bearing or suspension as the problem
Old Nov 28, 2013 | 07:57 AM
FatFrank's Avatar
FatFrank has a spectacular aura aboutFatFrank has a spectacular aura about
Frank,
Don't know about your car but mine uses the brakes and suspension even when in neutral....
FF
Old Nov 28, 2013 | 06:26 PM
VSKCHOI's Avatar
it happeded again today!! at slow speed...sounds like the muffler fell to the ground and dragging....I stopped the car and after 15 secs driving it disappear....I don't understand....something at this price I don't expect to hear these noises...and I mean they r loud enough that ppl can hear it across the street...
Old Nov 28, 2013 | 06:28 PM
VSKCHOI's Avatar
and I checked underneath the car..everything seems normal
Old Nov 28, 2013 | 10:28 PM
frankgtb's Avatar
my mistake
i meant coast to a stop in neutral to eliminate the transmission/drivetrain gearing down as the source of the noise and then start looking at brakes, wheel bearing and suspension
Old Nov 29, 2013 | 05:41 AM
jroback's Avatar
jroback is infamous around these parts
I have heard that disconcerting sound too, but fortunately not very frequently. The first time I heard it I stopped, jumped out and checked to see if something was dragging under the car. Then I took it to the dealer, they checked it out, and couldn't find anything wrong.
Old Nov 29, 2013 | 08:49 AM
VSKCHOI's Avatar
wellll....i guess thats just the way they are in cold days....i have to wait til April MAy to see if i hear these noises...
it usually happens when i slwo down, to 1st gear, but if coast to netural to a stop...no noise...
BenTT
Jul 22, 2021 02:38 PM
pwdrhound
Sep 13, 2016 10:44 AM
Bmanny
Sep 16, 2015 08:29 AM
h00pak
Cayenne 958
Sep 11, 2015 04:37 PM
jyupitt1
Sep 10, 2015 08:31 PM
