'05 DB9 Linn all discs 'unreadable'... help!
Old Apr 23, 2016 | 01:51 AM
K9COP's Avatar
K9COP is infamous around these parts
Hi guys, so the stereo in the DB9 suddenly decided it couldn't read any of the discs currently inserted. Removed all, re-inserted. Nothing. Constant 'unreadable disc' message.
Apart from the usual Linn = Boat anchor comments, any suggestions please?
Am I just at the 'life of English cars electronics'? (I'm English and have a Range Rover too, so I should have learned my lesson by now...
Thanks,
K9
Old Apr 23, 2016 | 06:54 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
It's a Volvo CD unit. There are some threads on Pistonheads about repairing/replacing the CD changer.
Old Aug 14, 2016 | 06:45 PM
K9COP's Avatar
Hi, I can't find those threads on Pistonheads, only upgrading. Could you help me with a link please?
Thanks,
Old Aug 14, 2016 | 08:52 PM
Oliver Goldsmith's Avatar
Oliver Goldsmith is infamous around these parts
I had this happen to me on my DB9 / Linn - it was fixed by running a CD head cleaner disc (wet) through a few times. Some gunk had got onto the laser lens.
Hopefully its that simple!
Old Aug 14, 2016 | 10:06 PM
K9COP's Avatar
Thank Oliver. I tried a 'higher end' cleaning disc today, and the head unit gave me the same result.. I'll try another cleaner disc and see what I get. Thanks for taking the time to reply.
K9
Old Aug 14, 2016 | 10:10 PM
Ah K9, good luck.
PS make sure you wait for the alcohol to evaporate before trying an actual music disc
PPS dry, abrasive cleaners didn't work for me - I had to use an actual wet (isopropyl aclohol based) solution to dissolve whatever it was blocking the laser
Old Aug 14, 2016 | 10:21 PM
K9COP's Avatar
"Ah K9, good luck.
Got it. Thanks mate.
K9
Old Aug 15, 2016 | 08:35 AM
yvr's Avatar
yvr
Here's a picture (from ambits) of the unit with part numbers visible:
Old Aug 15, 2016 | 09:22 AM
K9COP's Avatar
Thanks very much for this, that helps a lot. Without being lazy (I did search and couldn't find an answer), if I have to replace the unit, does it require a dealer visit to code it in, or is it plug and play please?
Many thanks, K9
speedracer800
Nov 17, 2020 01:09 AM
Johnny Mo
Cayenne 958
10
Apr 28, 2016 01:47 PM
pouch216
Apr 21, 2016 11:48 AM
zuman
Apr 20, 2016 05:17 PM
