Is it just me or
Old Apr 29, 2016 | 07:11 PM
handyman2009's Avatar
Veteran: Canadian Forces
Is it just me or
First off, I have a 2009 Vantage 6sp Man... Every once in a while, I put the key (plastic one) in the ignition, push on the clutch, other foot on the brake but the ignition never turn red which doesn't allow me to start the car. I take the key out and back in again and then it works... sometime I have to do it a few times before the ignition turns red so that I can push on the key and start. It doesn't happen every time so I really don't know what it could be, I first thought that it could be the steering lock but I hear it unlock. Does any one has a clue or is it happening to other people. Thanks
Old Apr 29, 2016 | 08:45 PM
XJRS Owner's Avatar
Use two flat finger technique to insert ECU.
Old Apr 29, 2016 | 09:25 PM
deckman's Avatar
It happens to me and have read it happens to others. I think it's mentioned in the book also, so I have assumed it's common.
Old Apr 29, 2016 | 10:21 PM
speedracer800's Avatar
speedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of lightspeedracer800 is a glorious beacon of light
I had this problem with my DB9 (non ecu car). I found it to be the connection on the clutch pedal switch which signals the pedal is fully depressed and car is safe to start.
Switch is located way up under the dash at the pivot point of the pedal basically. You could try reaching under and wiggling the wires with the pedal pressed to see if you get the start button to flicker.. Just a thought. Good luck.
Old Apr 30, 2016 | 05:24 AM
Thanks all I will investigate a little more time to see if I could identify the cause of the problem but it is pretty hard as it does it about 1 of every 5 starts of so. I will update this post if I find something obvious.
Old May 1, 2016 | 06:24 AM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
Wasn't there a TSB or recall in the ignition unit for incremental engagement?
I can't remember for sure, but I think I had read something about it somewhere.
Only time my 2012 SS does that is when I don't fully commit to pushing the key with one smooth motion.
Old May 1, 2016 | 07:47 AM
Thanks Batman-76
Old May 1, 2016 | 08:07 AM
XJRS Owner's Avatar
Not the same thing. OP is not asking about the single push, but rather the 2-stage start. While it may be a faulty part, the most frequent cause is overshoot on the initial 1st push to the flush position. The 2 flat finger technique generally solves this issue of no red light.
Old May 1, 2016 | 10:04 AM
deckman's Avatar
I just downloaded all the TSB's. I didn't see one about this.
Old May 1, 2016 | 12:40 PM
Thanks for the input XJRS, I will try to pay close attention and see if I do it properly and it still does it then you might be right which could lead to a faulty switch on the clutch pedal or the start mechanism where the fob goes in.
Old May 6, 2016 | 04:49 AM
Thanks XJRS, I never thought that I was overshooting the first push but ever since you said that I try to be more careful and use the 2 finger technique and I got a red light and start every time, at least for the last 10 start or so. I will keep my finger crossed (or flat in this case) that it was only a user problem.
Old May 6, 2016 | 05:11 PM
drivergmx's Avatar
drivergmx is a jewel in the roughdrivergmx is a jewel in the roughdrivergmx is a jewel in the rough
Did you push the throttle to the floor prior to engaging the starter? There is a post storage cold cranking feature which temporarily inhibits the fuel injection during cranking. This allows oil pressure to develop thereby delivering lubrication to the top end. Cycling the key will allow for normal starting on the second attempt.
Old May 6, 2016 | 05:42 PM
Thanks I did read that in the manual but I wasn't touching the gas pedal and it wasn't cranking at all. It was a user problem. All good now :-)
Old May 9, 2016 | 06:10 AM
Adrian928's Avatar
Adrian928 is infamous around these parts
This is somewhat related...Has anyone every done a standard Brit key-in-dash mount-start coversion? Assuming the steering lock has been disabled & kill switch.
Old May 10, 2016 | 10:32 PM
rhart6's Avatar
5 Year Member
rhart6 is infamous around these parts
Yep. XJRS nailed it. Took me a min. to figure out 2 flat fingers but it truly works.
EstorilM
Aug 17, 2016 01:05 PM
Wheel Dynamics
May 10, 2016 08:09 PM
spyder997s
Apr 7, 2016 12:45 PM
