OEM screen resolution??
Old Sep 5, 2016 | 12:31 AM
pikajew's Avatar
pikajew is infamous around these parts
Does anyone know what the screen resolution and dimensions are for a 2008 V8V sat/nav screen?
I would like to replace my sat/nav screen with a higher resolution one for an iPhone screen mirroring project.
Any recommendations for a good screen that actually fits?
Old Sep 5, 2016 | 02:33 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
6" wide or smaller, might be able to squeeze a 6.5 in wide.
3/4 of an in depth.
IF you mirror the dimensions of a Garmin 60LMT you will have what you need to know.
Old Sep 5, 2016 | 10:06 AM
embdenb's Avatar
This has been covered extensively. Search the archives. Unfortunately there is no easy fix for the original Nav screen.
Old Sep 6, 2016 | 01:41 PM
pikajew's Avatar
I have not seen any threads discussing the actual resolution of the OEM screen. Depending on the resolution, I may or may not replace the monitor itself. I'm installing a wireless cell phone mirroring module [thus rendering the antiquated Volvo nav useless] and if the OEM screen is decent, I'll just keep it and simply bypass the video feed to the wireless module. Audio will come from Bluetooth streaming upgrade module - part no. FD43-37-10167.
Old Sep 6, 2016 | 01:42 PM
pikajew's Avatar
3/4 of an in depth.
Much appreciated. Do you happen to know what the OEM resolution is?
Old Sep 8, 2016 | 12:33 PM
Zettinger's Avatar
Zettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of light
That sounds very interesting.
Looking forward to the outcome.
Old Sep 8, 2016 | 07:33 PM
hkg1997's Avatar
hkg1997 is infamous around these parts
Based on the Definitive Guide, the resolution is 480 x 234.
Old Sep 9, 2016 | 06:53 AM
deckman's Avatar
I have the newer Garmin unit with better Nav and higher resolution and still hate it. My fix? Don't use it. It really only comes up when in reverse.
Old Sep 10, 2016 | 11:38 AM
pikajew's Avatar
I hate it as well. But I'm doing a 1080p screen with hdmi in to connect to a module that lets me wirelessly stream from my cell phone.
I took the OEM Garmin unit out and will open up to stuff these into the old housing...
lkn4ubl
Jun 7, 2016 11:38 AM
Diginoise
May 1, 2016 09:57 AM
pikajew
Apr 19, 2016 12:56 PM
pikajew
Apr 4, 2016 12:59 PM
GT3Scott
Feb 5, 2004 10:05 PM
