Ooops! That's not going to be cheap.
Old Feb 14, 2018 | 12:13 PM
  #31
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Originally Posted by TheYoungConnoisseur
Would almost certainly be cheaper to put a used engine in instead of rebuilding and much faster.
best wishes
Are there any sources for used engines?
Old Feb 14, 2018 | 12:33 PM
  #32
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
Yikes. That sucks. Going to be hard to do a post mortem, but like others my guess would be oil starvation. I highly doubt a bearing or some other piece just failed. The question is what caused it. Seems improbable a galley to the head got blocked, but if there's no scoring in the cylinders and the rest of the bottom end is ok then sounds like there's was oil down there, especially considering it's a dry sump system. Anybody have good details about how the oiling system works? I'll have to look at the workshop manual.
Old Feb 14, 2018 | 03:38 PM
  #33
embdenb's Avatar
Originally Posted by Kanga
I'd use this as an opportunity to rebuild it to 5 liter spec and try for 500bhp. Race engines blow up all the time and get rebuilt, no difference with this one. Only concern would be what caused the failure in the first place as the car was regularly serviced and has spent plenty of time at the dealership.
If I remember correctly, stretching the engine to 5.0 is not going to be easy.
Old Feb 14, 2018 | 04:06 PM
  #34
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Originally Posted by HabitualOffender
But there is an important reason why everyone should have their cars serviced at the dealer.
What is the reason?
Old Feb 14, 2018 | 06:35 PM
  #35
silver997's Avatar
silver997 is infamous around these parts
Originally Posted by blue2000s
What is the reason?
The suspense is killing me..........
Old Feb 15, 2018 | 12:25 AM
  #36
Aston40's Avatar
Aston40 is a jewel in the roughAston40 is a jewel in the roughAston40 is a jewel in the roughAston40 is a jewel in the rough
Sorry for the loss. My first reaction was also very dry top part of the engine. Oil starvation.
All the best in fixing this.
Regards
Old Feb 15, 2018 | 09:10 AM
  #37
Zettinger's Avatar
Zettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of lightZettinger is a glorious beacon of light
Damn. I can't even imagine what thoughts are going through your mind.
As other mentioned, this is dry with no oil lubrication at all.
How full was the dry sump oil reservoir? I remember you mentioned your Vantage used up a large amount in a short time at one point.
  #38
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Yowsa! I am sorry to see this, and I hope you are able to come to the least painful resolution that is possible.
BTW, you are a now an official celebrity across the pond:
https://www.pistonheads.com/gassing/...f=70&t=1725128
Old Feb 15, 2018 | 03:27 PM
  #39
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Sorry, my pneumonia decided to get worse so I'm mostly just in bed now.
As I said earlier it was definitely starvation. The tech found something that's given a glimmer of hope but until the dominoes fall it's just "hope".
Anybody here that knows this car knows it's been meticulously over-maintained.
For my new fan club over the pond [all 3 of you LOL]
2010.25 V8V that was Daniel Craigs Hollywood car for 2010.
https://www.mi6-hq.com/news/index.php?itemid=9067
Chris from Newport Beach AM taught Craig how to drive a stick in this car.
Purchased by the original owner of record Rick Belluzo, ex President and COO of Microsoft.
I bought it from his agent September 2016 with 5700 miles.
It now has 17,500.
It missed its last yearly service because he only drove it 75 miles over the 2 years [IMO I think it stalled in a bad situation and spooked him from driving it. I also believe it probably stalled on Craig and that's why he turned it in after 2400 miles.]
When received the clutch was fried so I had the VAP/DAE twin plate installed and the full 6 year service done. It had stalled before but the pedal was stupid heavy and I always put it off to "I must have stalled it". In reality it stalls at about a 50/year pace by the records I kept. So thanks to an outstanding forum member Mr. Palmer got involved and mandated it be fixed, and England has spent alot of time and money trying to get it cured, including assuming it had to be the lightweight flywheel and they put a stock clutch in it. It stalled 3 days later. The last time it was in for 8 days swapping data and software with England, and developed a new bog problem which caused another driver to slam on his brakes to keep from drilling me.
I was down almost 2 quarts after 7000 miles and I didn't like how dirty the oil was so I had it serviced. When it was in for those last 8 days of data exchange we checked and it was down a quart at 5000 miles, which I have come to learn is fairly normal. We topped it off. So it had a full tank of 5000 mile oil, and as I was picking it up we figured out it was 5000 miles which is when I would have had it changed again and it could have been done while they had it those 8 days, but we just joked it would stall again and be back next month so we'd do the service then.
And then, it melted down and tore itself apart.
Old Feb 16, 2018 | 12:01 AM
  #40
Lve2xlr8's Avatar
Lve2xlr8 is infamous around these parts
Originally Posted by bunob
I know there is a problem on the 4.7 :
Anyone know the torque spec for the crankshaft bolt? Seems like good insurance to check every now and then!
Old Feb 16, 2018 | 01:15 AM
  #41
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
Habitual
this is a very sad situation - and when you are unwell
hope you get better & get a good result from your glimmer of "hope"
these cars shouldn't fail at 17k miles
best wishes
Graze
Old Feb 16, 2018 | 07:06 AM
  #42
Aldv's Avatar
Aldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud ofAldv has much to be proud of
Hi H-O...wow...I am shocked and sorry to read. Being sick only adds to the misery.
I am out of town and just saw your post. I wish you well. I will be interested in learning why the oil failure.
Good luck!!!
Duke
Old Feb 16, 2018 | 08:50 AM
  #43
blue2000s's Avatar
This sucks and I'm sorry this happened to you but I still don't see the point about needing to have the car dealer serviced.
Old Feb 16, 2018 | 10:16 AM
  #44
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
oof, that's pretty awful to hear. goodluck moving forward.
Old Feb 16, 2018 | 10:19 AM
  #45
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
My condolences
