Changing the battery concerns
Old Mar 6, 2018 | 09:27 PM
Jagman70's Avatar
Jagman70 is infamous around these parts
This Spring I plan on changing the 4 year old battery in my 09 Vantage roadster. It works fine now but I want to have a fresh battery in the car to avoid those potential weak battery problems that I hear about. I am concerned that if there is no power connected during the changeover, the car may lose its 'memory' for windows, convertible top, O2 sensors, etc.
I plan on doing the changeover myself. However, before disconnecting the battery cables should I connect a battery tender in the boot or attach jumper cables from another battery to the engine compartment battery posts so the car will always have some power connected to it during the changeover?
Old Mar 7, 2018 | 05:47 AM
embdenb's Avatar
Some battery “ tenders” have a setting the supplies current to the car while the battery is disconnected.
I like the idea of battery cables from another car or battery to supply current during the change over. If you use this method be aware that when you remove the battery cables from the defective battery they are still live. You must insulate the positive lead from the body.
Old Mar 7, 2018 | 07:52 AM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
Old Mar 7, 2018 | 08:39 AM
embdenb's Avatar
Originally Posted by DonL
Don
Good info for the DIY battery replacement guys.
Old Mar 9, 2018 | 07:40 PM
MikeD's Avatar
MikeD is infamous around these parts
At the risk of sounding like a jerk I can attest that, after changing the battery myself TWICE in the 7 years I've owned my DBS, there is nothing at all to be concerned with. And I'd bet anything that no Aston dealer runs jumpers to a car when changing a battery. It's just a car, not a volatile piece of scientific test equipment.
Old Mar 9, 2018 | 08:01 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
You can get the battery tested for it's ability to hold a charge at any auto parts store.
Old Mar 10, 2018 | 04:59 AM
handyman2009's Avatar
Veteran: Canadian Forces
Just as a side note, my car is park about 5-6 months of the year and the battery is disconnected for that period. Yes you will have to reset a few things like maybe the seat, windows, mirrors and radio stations and don't forget my car is MY09 so the misfire calibration. Like MikeD said above, just a car after all.
Old Aug 7, 2018 | 04:18 PM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
great info. .thanks.. only took 35 mins, but it seemed a lot longer. i lost count of how many swear words i used. the side panel removal was not clear. couldnt find any bolts or screws, so just left it in place and worked the front battery clamps off to the side and out, everything else was straight forward.
Old Aug 12, 2018 | 03:41 AM
GDay2's Avatar
GDay2 is a jewel in the roughGDay2 is a jewel in the roughGDay2 is a jewel in the rough
As far as I know you will loose the misfire correction parameters on the V8. To get your car to relearn them the AMDS is needed to initiate it.
Alternativly you can get your friendly one to make a backup and reload it after changing the battery. This means in both options you have to see AM.
Connect a 12v source while you are swapping the batteries and you avoid this hazzle.
Cheers
Christian
carrera4slakem
Cayenne
Feb 22, 2020 04:45 PM
0396
Jan 4, 2015 04:45 PM
ExclusiveTT
May 13, 2012 03:30 PM
TRSMatt
Apr 28, 2010 07:12 PM
cayenne_ksa
Mar 9, 2008 09:18 AM
