headlight LED array not working
Old Aug 24, 2018 | 09:54 AM
RolexDaytona1's Avatar
RolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura aboutRolexDaytona1 has a spectacular aura about
Originally Posted by BMW-North
Anyone looking for the Autosystems PCB board for the LED Array could likely pull the one out of this headlamp for $300 - LENS is cracked and xenon bulbs are pulled but you'd have spare ballasts & washer pump to boot.
https://www.ebay.com/itm/2008-2012-2...Ja4nB7&vxp=mtr
Just bought it.... $220
Anyone need a ballast or washer pump&cover?
Now to psych myself up for pulling the light out .... again. Blech.
Old Aug 24, 2018 | 11:20 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
Keep the ballast and pump as spares - you never know. If you have no use for the silver plastic shrouds I'll buy them off you and get you to ship 'em to my place in the US.
Old Aug 24, 2018 | 01:03 PM
HabitualOffender's Avatar
5 Year Member
HabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to allHabitualOffender is a name known to all
Speaking of the washers [even though you weren't], ASAIK mine have never worked even once. Are they on a separate fuse that may be blown?
Old Aug 24, 2018 | 02:07 PM
J doubleU's Avatar
All they do is make a mess, headlamps need to be on to enable spray with the windscreen washers. They are on a dedicated circuit under hood fuse box #26 (20AMP) fuse. So if someone didn't want them to work, pull the fuse. Everything else will work.
Old Aug 24, 2018 | 02:16 PM
5 Year Member
I know, I had a seller in Florida demonstrate his worked and he immediately had to pull out a towel and dry off his bonnet. I'd just like to know if they DO work
THANKS!
Old Aug 24, 2018 | 10:21 PM
BMW-North's Avatar
Before I’d let the washers work on any of these headlights I’d make sure they were resealed perfectly. .
Edit: Added the details from the WM re: Headlamp Washing
Old Aug 25, 2018 | 12:04 AM
5 Year Member
My bad, off topic again.
My fuse 26 is fine, but my lights are always on automatic. Is it the "automatic" that makes a difference?
Old Aug 25, 2018 | 07:18 AM
J doubleU's Avatar
No sir, on is on regardless of manual or auto position. Pumps can seize from lack of use. Supply lines are robust, and the pump is 2x the size of the windscreen pump. More audible so if you not hearing two different tones , could be the pump.
Old Aug 25, 2018 | 08:53 PM
5 Year Member
Thanks, next time it's raining out I'll stand outside the car and hit the washer button and see if I hear any pump action.
Talisman013
Jul 26, 2022 03:59 PM
PatrickBateman
Sep 4, 2014 05:35 PM
6t6
Jun 2, 2013 07:24 PM
Nydnarb911
Nov 9, 2012 03:01 PM
