TPM quick question
Old Feb 3, 2019 | 01:33 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
TPM quick question
The sender in the wheel, does it have a battery in it? If so how long does that last typically? How is it replaced?
if not does it use kinetic energy generated while the wheel turns?
Old Feb 3, 2019 | 01:36 PM
GT3Fan24's Avatar
GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !GT3Fan24 Is a GOD !
Yes and they last ABOUT 5 years. TPMS has to be replaced, not the battery. Hope that helps.
Old Feb 3, 2019 | 01:51 PM
thanks for the response, so the entire valve thing needs to be replaced?
is it a costly thing?
Old Feb 3, 2019 | 01:55 PM
GT3Fan24's Avatar
Yes the valve thingy and it is like replacing a tire (the labor of doing that). With no center locks they will charge you $25 or so a wheel to replace not including the cost of the TPMS. Those prices are all over the board based on which one you need.
Old Feb 3, 2019 | 06:43 PM
J doubleU's Avatar
The new ones need to be coded to the module by the dealer. $$ or you can bypass the system with a little know how.
Old Feb 3, 2019 | 06:46 PM
GT3Fan24's Avatar
Self learning. Coded from the TPMS place you get them and it will be included in the TPMS price.
Old Feb 3, 2019 | 07:02 PM
J doubleU's Avatar
Who sells those, and how much?
Old Feb 3, 2019 | 11:19 PM
this is better how does one do it?
Old Feb 4, 2019 | 04:22 AM
GT3Fan24's Avatar
They are all auto learn. If you give me your yr, make and model I will send you a link to purchase OEM replacement. They are programmed before sent to you. You then take the new TPMS to a dealer or any tire place. They will break the bead of your tire/wheel, they take out the old TPMS and then they install the new ones. You get in your car and drive and the new TPMS will learn the location and tell you the tire pressure reading. It is that simple. Only issue with Porsche is if you have CL wheels. I would not take my GT3 to a tire place so my dealer would swap them out for me.
Old Feb 4, 2019 | 08:00 AM
J doubleU's Avatar
Capt. You can order tire defeat from Redpants. Or Splice the wires together at the module after disconnecting it. Leave the Red
/Blue wire alone.
wolfnards
Nov 10, 2016 06:03 AM
hdawg
Jun 6, 2015 07:22 AM
akunob
Sep 8, 2014 01:44 PM
roro
Oct 17, 2010 02:08 PM
lbmw
Sep 11, 2009 06:38 PM
