Serpentine belt, tensioner and pulleys for DB9
Old Oct 15, 2019 | 08:05 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Hi,
FWIW, I cross matched the serpentine belt, tensioner and pulleys for my 2006 DB9. Got all of them from Amazon for about $100.00 US. You can get cheaper but these are either OEM or OE.
Dayco 5061070 Serpentine Belt
Dayco 89006 Tensioner & Idler Pulley (Need two)
Gates 38250 Belt Tensioner
https://www.amazon.com/gp/product/B0055ATA74/ref=ppx_yo_dt_b_asin_title_o08_s01?ie=UTF8&psc=1]ACDelco 36326 Professional Flanged Idler Pulley
Old Oct 16, 2019 | 07:31 AM
Carguy54's Avatar
Carguy54 is infamous around these parts
Nice find! Appreciate you sharing.
Old Oct 17, 2019 | 10:21 AM
ryanr317's Avatar
ryanr317 is infamous around these parts
Now just don't forget to post a DIY with pics.
Old Oct 17, 2019 | 05:32 PM
AM4884's Avatar
5 Year Member
I am looking forward to putting the engine back in the K-Frame. The belts go on almost last!
Old Nov 29, 2019 | 06:40 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Hi AM4884,
Can you describe your secretes how you find/mathc parts?
I have 2009 DB9 so Gates 38250 Belt Tensioner, is different, rest loss the same.
I would like to learn form you how you find compatible parts.
Thanks.
Old Nov 29, 2019 | 06:42 PM
Actually I take it back it looks like 05-85368 is same as Gates 38250 Belt Tensioner
Old Nov 29, 2019 | 07:37 PM
AM4884's Avatar
5 Year Member
No secrets, but in the main, AM uses a global supply chain, which was heavily anchored in Ford, and thus parts used by other Ford products. Most of the time the Ford part numbers are on the parts. In the case of the tensioner/belts these are standard parts with the length / width / diameter of the idlers easily determined. At that point I just go for the highest quality OE/OEM part available (staying away from low end parts). Gates and Delco make good stuff...
For the internals of the V-12, I purchased OE from either Rockauto or Partsgeek by buying for a 2005 V-6 3.0L Ford Escape. Just needed 2X the quantity...
YMMV,
Larry
Old Nov 30, 2019 | 08:20 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Thanks for sharing!
broncoupe
Nov 8, 2021 07:08 AM
gtmule
May 6, 2021 07:42 PM
André CHARLES
May 5, 2019 12:59 AM
Prefurbia
Dec 5, 2017 03:14 PM
karlfranz
Apr 17, 2012 10:00 AM
