Will a 2007 V8V parcel shelf fit a 2009?
Old Oct 21, 2019 | 01:07 PM
Kalepsis's Avatar
5 Year Member
Kalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to allKalepsis is a name known to all
A member on here messaged me saying he has a parcel shelf from his '07. Will the older ones fit a 2009 Vantage?
Old Oct 21, 2019 | 01:29 PM
handyman2009's Avatar
Veteran: Canadian Forces
I don't know the answer but found this from Aston Martin Bits:
REAR PARCEL SHELF.
THERE ARE 2 TYPES, THIS IS EARLIER TYPE, PART NO 6G33-46668-BCW CHANGE TOOK PLACE APPROX 2008. AML RETAIL IS £616.83
THE DIFFERENCE IS THE SIDE PINS ARE SPRING LOADED ON THE EARLIER TYPE - ONLY SEEN THEM IN BLACK, LATER ARE FIXED - ONLY SEEN THEM IN GREY.
WE HAVE TRIED LATE TYPE IN EARLY CAR WILL NOT FIT! NOT BEEN ABLE TO TRY EARLY IN LATE CAR YET.
Old Oct 21, 2019 | 01:34 PM
MRCW's Avatar
compare part numbers
Old Oct 21, 2019 | 01:45 PM
Graze's Avatar
5 Year Member
Graze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to allGraze is a name known to all
I can try an 07 shelf in a 17 car if you want me to
might give u some idea if it will fit in an 09
Graze
Old Oct 21, 2019 | 02:13 PM
Kalepsis's Avatar
5 Year Member
Graze
Please and thank you. That would be great.
Old Oct 21, 2019 | 04:36 PM
Graze's Avatar
5 Year Member
yep the 07 fits in the 17 car
dont think they would work the other way around due to the fixing
the essential difference is the 07 has a spring loaded pin on each side controlled by a small pull tab which sits under the rear section of the shelf. to remove it you pull the tab and the pins retract
in the later car the shelf is about half the weight & has plastic tabs which slide up and over a "hook" in the guide on each side
so if you pushed the later version into the earlier fitting I dont know if you'd get it out again
But for what you need it will work a treat
Graze
Old Oct 21, 2019 | 05:03 PM
Kalepsis's Avatar
5 Year Member
Graze
Thank you very much, Graze!
Old Oct 22, 2019 | 03:08 PM
RamVA's Avatar
RamVA is infamous around these parts
FWIW, I have an '08 and the package shelf with the retractable pins kind of sucks. It's fiddly to release, quite heavy and annoying to handle once it's out of the car, and mine falls down on one side within a few miles of driving. I'd recommend getting the later one, but that's easy to say when it's not my money.
Old Oct 22, 2019 | 03:16 PM
Kalepsis's Avatar
5 Year Member
I appreciate the input. The good thing about the newer car is that I won't actually need to use the spring-loaded pins to remove it. And if worse comes to worst I can at least use the '07 shelf as a template to design and build a custom one out of carbon fiber or fiberglass and cover it in Alcantara.
Old Oct 29, 2019 | 02:49 PM
talltim's Avatar
talltim is infamous around these parts
Yes and it fits better
The earlier, now discontinued, premium parcel shelf fitted fine in my 2012 vantage
Old Oct 29, 2019 | 02:52 PM
Kalepsis's Avatar
5 Year Member
Problem solved
I got the parcel shelf from another member here and it works perfectly. I have less road noise in the cabin now, too.
Old Oct 30, 2019 | 04:52 AM
Graze's Avatar
5 Year Member
good to hear
Graze
Old Oct 30, 2019 | 10:01 AM
got one's Avatar
got one is infamous around these parts
Do you mean the cover or the actual shelf?
Old Oct 30, 2019 | 06:31 PM
RamVA's Avatar
He's talking about the folding, removable cargo cover in the hatch, not the narrow behind-seat shelf that covers the battery and toolkit.
Old Oct 30, 2019 | 06:46 PM
Kalepsis's Avatar
5 Year Member
Yes, this. It's also sometimes called a package tray, but the OEM parts list on Scuderia Parts website is "parcel shelf".
Psycho123
Jul 15, 2020 05:40 AM
Allen121
Jul 20, 2017 08:34 AM
Jeff1smith
Nov 8, 2014 10:18 AM
Montalvo
Jun 13, 2009 09:16 AM
