Ctek
Old Apr 3, 2021 | 04:58 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Ctek
What ctek charger/tender unit do I need for 2007 Vantage. Thanks in advance.
Old Apr 3, 2021 | 06:34 PM
J doubleU's Avatar
NOCO genius 1 or 2 models get my vote. $30-$50 and add on the 12v power port connection.
Old Apr 3, 2021 | 07:17 PM
V12Stealth's Avatar
5 Year Member
V12Stealth
I have the big Ctek Multi but I don't use it as a trickle charger. I use it to charge old/dead batteries in my classic cars. I'd never leave it unattended for very long. Even the best chargers will overheat or go into an error mode and overcharge a battery and cause fires. If you want something safe you can hookup and forget, I would always recommend the lowest power rated ones like the CTEK US 0.8 [unlink]https://smartercharger.com/collections/vehicle/products/ctek-us-0-8[/unlink]
Last edited by V12Stealth; Apr 3, 2021 at 07:22 PM. Reason: Trying to remove the hyperlink
Old Apr 4, 2021 | 05:54 AM
kdm's Avatar
kdm
5 Year Member
kdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of lightkdm is a glorious beacon of light
I have a couple of the CTEK - 40-206 MXS 5.0 chargers for our 2007 V8V and for the 911. Have used them for the past 4 years with no issues. The cars stay plugged in all the time when parked. For the Aston I use the power port in the trunk. The port fitting is a little loose so you need to ensure it is making contact. I'm able to close the trunk lid and it doesn't crush the cord.
However I have proven a couple of times they do not travel well when you leave them plugged in and drive away. After 5 or 6 miles at highway speeds, trailing behind the car, they do not seem to work for some reason... . The latest replacement arrives today.
Old Apr 4, 2021 | 06:10 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
I am having the dealer install the magnetic connector next to the license plate lights like come standard on the new Aston's. The dealer hasn't converted one yet, but didn't think it would be too big a job. I drove off with the cord still connected in car once too
Old Apr 4, 2021 | 06:34 AM
MRCW's Avatar
ha! that's my problem with electric cars... can't find extension cords long enough...
Old Apr 4, 2021 | 08:50 AM
tdibs's Avatar
tdibs is infamous around these parts
I also use the lighter in the trunk for charging with a battery tender. I close the trunk but don't click it shut...that way I get a warning light that my trunk is open before I can pull away without disconnecting. It's saved me a few times
Old Apr 4, 2021 | 09:20 AM
MAUMAU's Avatar
MAUMAU is infamous around these parts
Kevin -
With your newly installed exhaust system (read LOUD) why don’t you just pump the accelerator a few times before you back out of the garage. The noise alone will most likely unplug your charger automatically and probably blow off any dirt or bugs at the same time. It’s a win win situation!
Old Apr 4, 2021 | 10:35 AM
kdm's Avatar
kdm
5 Year Member
Originally Posted by MAUMAU
Kevin -
Rob - I'll have to try that next time.
Tdibs - thanks for that idea. Sometimes the simple solutions are the best
Old Apr 5, 2021 | 05:51 AM
5 Year Member
Smile
I now keep an orange microfiber towel in the trunk. When I plug the car in, put the towel on my windshield so I know to unplug it before leaving.
APF
Mar 5, 2021 12:25 AM
topofthemorning
Jun 20, 2020 11:09 PM
buckarooboy
Oct 16, 2018 01:27 PM
SoulMaster
Cayenne 958
Jan 5, 2015 03:24 PM
Falcon75
Oct 7, 2014 12:53 PM
