Question on V8 vantage power delivery under 3500 rpm
Old May 8, 2021 | 11:35 PM
dyc1077's Avatar
dyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud ofdyc1077 has much to be proud of
Hi all. I am looking to purchase one of these magnificent machines and test drove a manual transmission 2006 v8 vantage for the first time today. Loved the visual, the sound, and the quality of the materials. But what I did find lacking was the amount of power off the line under 3500 rpm or so. Is that a normal characteristic of the v8 vantage power band? The car is supposed to have the AMR power pack and I think a tubi exhaust. I am definitely not used to the counterclockwise tachometer and that will take time to get used to. Before I purchase the car, I want to make sure that is a normal characteristic and not a sign of some issue. Thanks in advance.
Old May 9, 2021 | 03:32 AM
convexproblem's Avatar
convexproblem is infamous around these parts
Yep it's normal. The 1st gear is on the tall side, the cams are big, and the car is heavy, so you don't get a whole lot of grunt off the line. It feels close to an Infiniti G35 until you rev it out a bit more. The 4.7 is a little stronger but it still gives its best at high rpm. A tune and dual plate clutch + lwfw kit can probably make it feel a teeny bit quicker off the line.
Old May 9, 2021 | 01:22 PM
61mga's Avatar
61mga is infamous around these parts
the throttle response is abysmal on the early vantages. both on and off throttle IMO. (i've got one) and in reverse it's even worse. i don't race around much, so it's not an annoyance for me.
Old May 9, 2021 | 02:22 PM
J doubleU's Avatar
Stock tune yes, spring for a Velocity AP tune it will make it better.
-JW
Old May 9, 2021 | 04:41 PM
dyc1077's Avatar
Thanks for the responses. Looks like I am going to get this v8 vantage. It has the aston Martin power upgrade kit and a tubi exhaust. Timing gasket replaced last year. And only about 5k miles on the car. I ll drive it a bit and get used to it. Then decide what next steps if any (maybe the dual clutch and/or headers).
Old May 9, 2021 | 04:46 PM
It's the pedal mapping. If you jab the pedal very quickly, the engine does respond without delay (unlike e.g. a Prius which smooths and delays throttle input). You get like like nothing for the first bit of travel, and then the torque increases linearly with pedal input, whereas most cars are set up to imitate a cable throttle (more torque in the first part of the pedal travel).
I find I got used to just stepping harder and faster on the pedal, but a tune that changes the mapping would make it feel more sporty for sure.
Old May 9, 2021 | 07:29 PM
61mga's Avatar
thanks...
always wondered why there wasn't a readily available remapping for the pedal. usually such things are relatively accessible to those that do aftermarket re-programming, etc...
Old May 10, 2021 | 09:32 AM
Christian Cameron's Avatar
5 Year Member
Christian Cameron is infamous around these parts
pictures!
Old May 10, 2021 | 07:25 PM
dyc1077's Avatar
Just posted a couple pics of the car here
https://www.6speedonline.com/forums/...ml#post4876365
3rdpedalrequired
Aug 3, 2024 03:29 AM
Matt Lane
Apr 24, 2020 10:25 AM
darkusAM
Feb 9, 2014 08:37 PM
danielg69
Apr 9, 2010 10:18 AM
