CEL on
Old Jun 14, 2021 | 11:41 AM
Marmot's Avatar
5 Year Member
Marmot has a spectacular aura aboutMarmot has a spectacular aura about
CEL on
Well, I have the Check Engine Light on with a message about service being required. I ordered a Foxwell scanner the same day to find out more, but is there any way to extinguish the CEL? I was able to remove the message by pressing the 1/2 buttons on the stack, but the CEL stays on. The light came on after an extended period of idling and stop and go at low speed, I checked fluids and oil was a small bit high so I am not sure if that is related. I sucked out the surplus to the top line on the dip stick. Car is idling and driving fine, so I don't suspect a misfire yet. Any advice would be helpful!
Old Jun 14, 2021 | 12:02 PM
convexproblem's Avatar
convexproblem is infamous around these parts
I always keep a basic bluetooth OBD2 scanner in my cars so I can check the codes and such at any time. The ELM327 knockoffs are 6 bucks on Ebay and work okay for this purpose.
Old Jun 14, 2021 | 12:40 PM
bavarianstance's Avatar
5 Year Member
bavarianstance is infamous around these partsbavarianstance is infamous around these parts
Foxwell will be able to read and clear codes. Nothing you can do in the meantime without the tool I'm afraid.
Old Jun 14, 2021 | 12:43 PM
Marmot's Avatar
5 Year Member
Good to know, thanks! I guess I will avoid driving it in that case.
Old Jun 15, 2021 | 06:37 AM
Marmot's Avatar
5 Year Member
Autozone had occurred to me but for whatever reason I figured that they could not read A.M. codes or clear them. They can for BMW, Land Rover, Jaguar etc. so I am not sure why I concluded that. I may stop by in the interim while I wait for the Foxwell to show up and see if they can help. Thanks!
Old Jun 16, 2021 | 10:26 AM
gaussianmist's Avatar
gaussianmist is infamous around these parts
How did you remove the excess oil? I've tried a turkey baster but it is way too slow.
Old Jun 16, 2021 | 11:58 AM
Marmot's Avatar
5 Year Member
Went to Advance Auto Parts and bought a pump that screwed to a quart and gallon container and eyeballed the dipstick how high over it was and pumped out roughly that much on the dipstick. It wasn't much, maybe 2 cups at most. Total cost $7.99 and an almost empty 1/2 gallon of milk about to turn...
Old Jun 18, 2021 | 10:52 AM
Marmot's Avatar
5 Year Member
Autozone did indeed work. Code P0174, Left bank lean OR rich...that is as specific as they could get. They were able to clear the code. The 5 miles back home did not get the light to come on again so I assume it is intermittent...
Old Jun 20, 2021 | 08:46 AM
ccfulton's Avatar
ccfulton is infamous around these parts
Once you have your own reader you can watch the fuel trims while driving and see for yourself if any of them are particularly high.
wsuhottboi
Bentley
16
Oct 19, 2017 01:05 PM
wsuhottboi
Bentley
Oct 5, 2017 04:54 PM
SAVED4IT
Dec 18, 2009 11:05 AM
jaykla
Dec 4, 2007 03:36 PM
jamie furman
Nov 26, 2007 07:32 PM
