2006 db9
Old Jul 22, 2021 | 01:24 PM
mistakeum's Avatar
mistakeum is infamous around these parts
2006 db9
why does the fan in the trunk remain on? what is the purpose of the fan? I individually removed each fuse in the trunk fuse box and the fan stays on! It's probably the reason I needed another battery. Please help, thanks
Old Jul 22, 2021 | 01:43 PM
J doubleU's Avatar
Audio amplifier fan, you can try taking the T-30 Torx screws off the carpet panel for access to the inline fuses and connections at the amplifier.
Old Jul 22, 2021 | 05:51 PM
mistakeum's Avatar
Thank you!!! - I will try.
Old Jul 22, 2021 | 07:04 PM
AM4884's Avatar
5 Year Member
AM4884 has a spectacular aura aboutAM4884 has a spectacular aura aboutAM4884 has a spectacular aura about
Mine def runs after I shut the car off. Turns off after a while....
Old Jul 4, 2022 | 10:49 AM
mistakeum's Avatar
how can I obtain a wiring diagram for the Linn amplifier in my '06 DB9? I'm thinking a faulty relay or switch is not shutting the fan off. Thanks
Old Jul 4, 2022 | 10:55 AM
J doubleU's Avatar
It's a timer vs temp built into the unit, it eventually turns off. If it still running after an extended period then it's an amplifier problem.
Old Jul 4, 2022 | 01:17 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
I have the Linn 950W system on my '04 DB9 and the fan takes sometimes ages (as in an hour or so) to turn-off. It will turn off eventually
Old Jul 5, 2022 | 06:19 AM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
Mine behaves the same as sdekoning's. You DO use a battery tender, right? My CTEK gets plugged in the moment my DB9 returns to my garage...
By the way, Fuse F65 in the CABIN fuse box is described as "5 Amp – Media play / Multi media module and display / Antenna amplifiers / Audio amplifier." It's clearly not the main amplifier fuse, but part of the control circuit.
Old Jul 5, 2022 | 04:51 PM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
My "05 DB9 does the same thing. Never timed it but it does eventually stop. I leave the hood and trunk open after a drive. I can hear the fan.
broncoupe
Nov 8, 2021 07:08 AM
Wildcat1212
Sep 9, 2018 05:17 PM
randyb
Jun 17, 2018 08:00 AM
zuman
Jul 2, 2016 09:31 AM
Jeff1smith
Dec 7, 2014 03:27 PM
