Cracking Taillights
Old Feb 16, 2022 | 05:26 PM
Sir Rothschild's Avatar
Sir Rothschild is infamous around these partsSir Rothschild is infamous around these parts
Cracking Taillights
Hello All,
My tail lights are starting to have minor cracks in them. See pictures. Not sure why or how this is happening. It is happening on both sides. Anyone experienced this or know the cause? 2011 V12 Vantage.
Old Feb 16, 2022 | 05:39 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
That's really strange.
Old Feb 16, 2022 | 06:59 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
How long have they been installed? They could be over tightened as the cracks are in the same place on both lights? I would consider a clear thin super glue type substance (maybe some one has a suggestion of what to use sparingly) that will keep water out and stop the crack from spreading! You might need to remove the lights to apply so that the glue doesn't run on the light surface, or use plenty of blue painters tape to cover surfaces. If the fasteners are over tightened I'd back them off 1/2 turn. Sorry your having the issue!!
Old Feb 17, 2022 | 05:14 AM
MichaelD's Avatar
MichaelD is infamous around these parts
There are three adjustable bolts behind each light, they need to be adjusted then tightened, if someone didn't adjust them first, then tightening the bolts will put some bending force on the lights and something will break.
Old Feb 17, 2022 | 05:29 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Never seen that before - I'd guess MichaelD is right - someone did not know what they were doing when reinstalling them probably to deal with moisture getting in.
Old Feb 17, 2022 | 09:59 AM
Yes, I think the overtightening theory is probably correct. Thank you everyone for the input. So now the question is, how do you know what the correct adjustment is?
Old Feb 17, 2022 | 10:14 AM
5 Year Member
I removed mine before, and it was the biggest pain in the a** to align properly. Never seen tail lights with so much slop/play/adjustment in the in my life. Just a shame Aston never corrected them. There are posts on here how to do it, I never saw before I did mine. Unfortunately from those cracks, if it were mine I would just leave them until I bit the bullet for new ones.
Old Feb 17, 2022 | 10:25 AM
Does anyone have a link to the adjustment posts? Please!
Old Feb 17, 2022 | 10:43 AM
bobdisp's Avatar
5 Year Member
bobdisp is infamous around these parts
Old Feb 17, 2022 | 11:14 AM
5 Year Member
ralph s3
Jul 20, 2022 11:42 AM
Sir Rothschild
Feb 16, 2022 05:00 PM
daffyduck
Mar 21, 2019 04:32 PM
boochook
Mar 22, 2013 10:39 AM
f360c5
Oct 22, 2010 04:47 AM
