Battery Tender
Old Apr 10, 2022 | 05:51 PM
xjjeepman's Avatar
xjjeepman is infamous around these parts
Question Battery Tender
Hello all, my father has a 2011 Vantage, and I don't believe it had a battery charger with it when he purchased it. Is there a way to just use a Battery Tender on these cars? Do we have to use the port in the trunk or can we use the positive post under the hood to hook up to?
Old Apr 10, 2022 | 07:39 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
I use the trunk point in my 08..no issues..
Old Apr 10, 2022 | 08:54 PM
J doubleU's Avatar
Absolutely, you can hook up to the under hood with any charger. Definitely don't want it to go below 12v as interesting things will happen. Hopefully the current battery is up to date so your not wasting your time.
Old Apr 11, 2022 | 05:27 AM
xjjeepman's Avatar
Thanks guys. So checking to see if the battery is up to date is just accessing the battery compartment and checking the date to see if its in the 5-7 year range right?
Old Apr 11, 2022 | 07:06 AM
J doubleU's Avatar
Should have the battery tested as sometimes date codes aren't reliable. If in doubt start with a fresh battery.
Old Apr 11, 2022 | 07:15 AM
xjjeepman's Avatar
Thanks, what battery do you recommend? Anything in specific? Or can I go to my local napa?
Old Apr 11, 2022 | 07:27 AM
J doubleU's Avatar
Any place that's convenient, H8 battery most places have it. My last one was Duracell from Sam's club. Only cause Costco was out of stock. Pretty much use Interstate in everything.
Old Apr 11, 2022 | 10:12 AM
NotanM's Avatar
NotanM is infamous around these parts
See below, this is what I have used with great success, set & forget!
https://smartercharger.com/collectio...s/ctek-mxs-5-0
You'll need this adaptor if you want to plug it into the 12v port:
https://smartercharger.com/collectio...cator-cig-plug
Old Apr 12, 2022 | 07:50 AM
xjjeepman's Avatar
Thanks!
Old Apr 12, 2022 | 08:11 PM
J doubleU's Avatar
Shop around, they can be had for less.
Old Apr 13, 2022 | 04:21 PM
UltraMarine's Avatar
UltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to allUltraMarine is a name known to all
FYI, the current OEM charger by Aston Martin ( https://i.ebayimg.com/images/g/0yQAA...-t/s-l1600.jpg ) is a relabeled Optimate6. MSRP is $499
You can buy a Optimate 6 or Optimate 7 for about $100 on eBay.
https://optimate1.com/prod/chargers/
I use one of those and they are great. (I have used Ctek and Noco in the past)
Old Apr 14, 2022 | 03:49 PM
zuman's Avatar
zuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud ofzuman has much to be proud of
I've used the CTEK Multi-US 7002 for the eight years I've owned my DB9, and I consider it my car's most important "tool." It's never failed me. I suspect it's what most owners use.
I grafted a three-pin connector to the output to fit the port in my trunk, and it just does its thing. Less than $125 on Amazon.
minming
Jun 10, 2021 01:00 AM
embdenb
Feb 16, 2020 06:15 PM
Jagman70
Aug 12, 2018 03:41 AM
minming
Dec 21, 2017 10:29 AM
cuddapah
Oct 30, 2017 05:30 PM
