15' Vantage Bluetooth Audio?
Old May 17, 2022 | 12:51 PM
downeaster1's Avatar
downeaster1 is infamous around these parts
Hey all,
I just picked up a 15' Vantage with the technology package, and a bit confused about the bluetooth. It has bluetooth phone calling, but the manual lists that it's capable of bluetooh audio. It instructs to pair the phone, then select the "mode" button and scroll to "BT" as an option, but that option doesn't exist. Does this mean I don't have bluetooth audio? Thanks!
Old May 17, 2022 | 02:41 PM
61mga's Avatar
61mga is infamous around these parts
i can't answer your question, but FYI,
according to this website: https://www.motortrend.com/cars/asto...-vantage/]2015 Aston Martin V8 Vantage Buyer's Guide: Reviews, Specs, Comparisons (motortrend.com)
bluetooth is standard on the 2015 vantage. ...but...
the 2015 vantage owner's manual shows it as optional on all the stereos.
not to insult your intelligence, honest(!), but bluetooth needs to be switched "on" on your smartphone of course. i only mention it because the aston user's manual does. ...really...
Old May 17, 2022 | 04:23 PM
I should have specified; bluetooth phone calls work just fine, but I can't seem to get the music streaming to work.
Old May 17, 2022 | 04:39 PM
61mga's Avatar
if you can show us the vin, there might be a way to get the build list...which should show us the options.
Old May 17, 2022 | 05:19 PM
SCFEBBAL4FGC18600
Old May 17, 2022 | 05:29 PM
61mga's Avatar
Engine: 4.7L V8 32-Valve DOHC
Rear-Wheel Drive
3.91 Axle Ratio
Front And Rear Anti-Roll Bars
Premium Shock Absorbers
Sport Tuned Suspension
Hydraulic Power-Assist Speed-Sensing Steering
21.1 Gal. Fuel Tank
Dual Stainless Steel Exhaust w/Black Tailpipe Finisher
Double Wishbone Front Suspension w/Coil Springs
Double Wishbone Rear Suspension w/Coil Springs
4-Wheel Disc Brakes w/4-Wheel ABS, Front And Rear Vented Discs, Brake Assist and Hill Hold Control
Mechanical Limited Slip Differential
Safety
Side Impact Beams
Dual Stage Driver And Passenger Seat-Mounted Side Airbags
Rear Parking Sensors
Low Tire Pressure Warning
Dual Stage Driver And Passenger Front Airbags
Airbag Occupancy Sensor
Outboard Front Lap And Shoulder Safety Belts -inc: Pretensioners
Back-Up Camera
Interior
Power Sport Bucket Seats
Driver Seat
Passenger Seat
Manual Tilt/Telescoping Steering Column
Fixed Rear Windows
Sport Alcantara Simulated Suede Steering Wheel
Front Cupholder
Valet Function
Power Fuel Flap Locking Type
Remote Releases -Inc: Power Cargo Access and Power Fuel
Garage Door Transmitter
Automatic Air Conditioning
Illuminated Locking Glove Box
Driver Foot Rest
Full Alcantara Simulated Suede Headliner
Leather Gear Shifter Material
Interior Trim -inc: Carbon Fiber Instrument Panel Insert, Carbon Fiber Door Panel Insert, Piano Black Console Insert, Piano Black Interior Accents and Simulated Suede Upholstered Dashboard
Alcantara Simulated Suede Door Trim Insert
Day-Night Auto-Dimming Rearview Mirror
Full Floor Console w/Covered Storage and 2 12V DC Power Outlets
Front Map Lights
Fade-To-Off Interior Lighting
Full Carpet Floor Covering -inc: Carpet Front Floor Mats
Carpet Floor Trim and Carpet Trunk Lid/Rear Cargo Door Trim
Folding Cargo Cover
FOB Controls -inc: Cargo Access
Driver And Passenger Door Bins
Power 1st Row Windows w/Driver And Passenger 1-Touch Down
Systems Monitor
Redundant Digital Speedometer
Outside Temp Gauge
Analog Appearance
Fixed Front Head Restraints
Front Center Armrest
Seats w/Leather Back Material
Perimeter Alarm
Engine Immobilizer
Air Filtration
Exterior
Tires: P245/40ZR19 Fr & P285/35ZR19 Rr Bridgestone Potenza RE050
Aluminum Spare Wheel
Compact Spare Tire Mounted Inside
Clearcoat Paint w/Stripe
Body-Colored Front Bumper
Body-Colored Rear Bumper
Aluminum Side Windows Trim
Body-Colored Door Handles
Colored Power Heated Side Mirrors w/Power Folding
Fixed Rear Window w/Defroster
Light Tinted Glass
Rain Detecting Variable Intermittent Wipers w/Heated Jets
Galvanized Steel/Aluminum/Composite Panels
Lip Spoiler
Black Grille
Liftgate Rear Cargo Access
Auto On/Off Projector Beam High Intensity Low Beam Auto-Leveling Headlamps w/Washer and Delay-Off
LED Brakelights
don't see anything about bluetooth...hmmm...
would help if someone with a 2015 vantage known to have bluetooth option could provide a vin to compare yours to... eh?
Old May 18, 2022 | 12:56 AM
happyh's Avatar
happyh is infamous around these parts
Hi,I have a 2015 V8 Vantage(MY 2016) and my audio streams just fine. VIN SCFEABAKXGGC20363
Heres info from the technical hub:
BODYSTYLE CODES FOR CONFIG Code for Coupe EXHAUST Standard Muffler BODYPACK RIM - Bodypack - ROW LEATHER KIT Leather Kit - Standard IP LANGUAGE Language - English MODEL YEAR OPTION Model Year 2016.00 GEAR SHIFT SURROUND Gear Shift Surround - Silver BLUE TOOTH MODULE 08MY Onwards Bluetooth Module ACTIVE DAMPING Ambient Temp/Passive Damp MULTIMEDIA MODULE Nav Unit - Euro REAR BUMPERS Rear Bumper with PDS - RoW VIN PLATES Legislative Labels - RoW LABELS Labels - Row WHEEL CENTRE CAPS W/Badge - Silver / Green Wings (UK) AIRBAG Green Wings Badge / Silver Horn Ring BONNET MESHES Hood Mesh - Platinum BRACKET FUEL TANK VENT Bracket Fuel Tank Vent - Non Fed SIDE STRAKE Side Strake Standard DOOR BOARDS Door Board - Powerfold / Alpine WHEELS 5 spoke Silver - 433Mhz HEATED FRONT SCREEN Front Windscreen with Antenna MIRROR CAPS Mirror Cap - Body Colour PARKBRAKE FUNCTIONS Parkbrake Functions Off FUEL FILLER CAP Fuel Filler Cap - Polished Aluminium HANDBOOK LANGUAGE English SILL PANEL N400 Sill Panel Design MASTER LIGHTING SWTICH Master Lighting Switch - Auto Lights NOISE VIBRATION HARSHNESS Fit Bonnet NVH HEADLINING OUTER Headlining Outer - Alcantara ICM SETTINGS ICM Settings - 14my Intro WINDOW SURROUND FINISHER Bright - DLO Surround FOAM KIT Foam Kit - 2 Piece Sports Seat ENGINE CALIBRATION Row Engine Calibration PROTECTIVE FILM N400 Sill Helitape HEADLAMPS Headlamps Silver Bezel PROGRAM CODES VH217 2016MY Vantage BINNACLE AND SHROUD Leather Binnacle and Shroud MICROPHONE Microphone TERRITORY OPTION CODE UK CENTRE CONSOLE Centre Plate - Graphite RADIO SYSTEMS ANTENNAS Radio System Antenna -FM/DAB Phantom Fed PASSENGER AIRBAG DISABLE SWITCH PAD Switch / Console Plate Lamp CABIN CARPET Sill & Tunnel Carpet Non B&O/720gsm TREAD PLATES Treadplate Finish - Platinum TRIM UPPER IP Obsidian Black Leather (LX57) FRONT GRILLE Standard Grille Platinum CARPET STITCHING Silver (N2829) - 10M SEAT OUTER STITCHING Silver (N2829) - 10M SEAT INNER STITCHING Silver (N2829) - 10M SEAT TYPE OUTER MATERIAL Sports Seat Outer Standard Lthr TRANSPORT BAG DO NOT FIT TRANSPORT BAG ROOF INNER COLOUR Tailors Grey Alcantara FACIA TRIM (TRIM INLAY) Full Facia - Graphite STRG WHEEL COLOUR Obsidian Black Leather (LX57) REAR DIFFUSER Rear Diffuser Blade - Body Colour STRG WHEEL STITCHING Standard HEADPHONES No Headphones TRIM STITCH UPPER Silver (N2829) - 10M INTERIOR TRIM PACK Interior Hardware - Graphite TRIM STITCH LOWER Silver (N2829) - 10M MESHES Meshes - Standard CARPET COLOUR Obsidian Black DRIVE Right Hand Drive SEAT OUTER COLOUR Obsidian Black Leather (LX57) BODYSTYLE Coupe SEAT INFILL COLOUR Obsidian Black Leather (LX57) TRANSMISSION Manual COLOUR Meteorite Silver (P5120AAB) GEARBOX TYPE Manual SEAT CONFIGURATION 2+0 GLOBAL CLOSE No Global Close VEHICLE DESCRIPTION V8 Vantage Coupe PERFORMANCE B MASS MOVEMENT SENSOR No Mass Movement Sensor VEHICLE PROGRAM VH217 AIR BAG WARNING LABEL Airbag Warning Label - ECE94.01 S4 HVAC UNIT Fit HVAC Unit V8 - Cold TRIM COLOUR UPPER Obsidian Black Leather (LX57) REAR LAMP CONFIG Rear Lamp - Vantage Clear TRIM COLOUR LOWER Obsidian Black Leather (LX57) SEAT TYPE INSERT MATERIAL Sports Seat Inner Standard Lthr EMERGENCY BREAKDOWN LABEL Emergency Label - Euro HEADLAMP AIM LABEL Headlamp Aim Label - Non FED WASHER JETS Non Heated Washer Jets RAIN SENSOR Rain Sensor STEERING COLUMN Electronic Steering Column SEAT INGRESS / EGRESS Do not fit Seat Ingress/Egress Switch STONEGUARDS Stone Guards Not Required REAR ENVIRONMENT MATERIAL Rear Environment Material - Leather SEAT TYPE Pass Isofix Non Height TYRE PRESSURE MONITORING TPMS - 433Mhz (do not fit bracket) SILL PLAQUES Standard Sill Plaques FORWARD HARNESS Forward Harness - HID / Non HFS CABIN CARPET Standard - Floor Carpet REGIONAL CODES FOR CARS 2 Codes For UK SATELLITE NAVIGATION Satellite Navigation FUEL TANK Fuel Tank - Others WATERMARK MODEL DESCRIPTION V8 ANTENNAS FITTED Rear antenna only fitted SEAT BELT REMINDER FUNCTION Seat Belt - 2 door - ROW VIRTUAL CENTRE STACK Sat Nav Virtual Stack FACIA TYPE AND NAV SCREEN Wood Facia with Sat Nav Screen MEMORY SEATS Non Memory Seats ENGINE TYPE V8 Standard Engine SIDE STRAKE MESHES Side Strake Mesh - Platinum HEADLAMPS HID Headlamp - Wash and Levelling - RHD GEARKNOB Black Gearknob (Vantage) RIDE HEIGHT SENSOR/H-LAMP LEVELLING No Ride Height Sensor/H-Lamp Levelling CENTRE CONSOLE STOWAGE Non Smokers Kit INSTRUMENT PACK Instrument Panel - UK/USA STEERING WHEEL Std Steering Wheel - B/Tooth / Cruise FRONT HEADER Non GSM Telephone UNDERBONNET INSPECTION PLATE Underbonnet Inspection Plate - Std REAR BADGE Fit Vantage Badge INTERIOR REAR VIEW MIRROR Rear View Mirror (Std) MPH(0-60) . FIRST AID KIT No First Aid Kit STEERING/ENGINE MOUNTS Standard AML Steering/Engine Mounts KPH(0-100) . MPG URBAN . FRONT BUMPERS Front Bumpers PDC -RoW (With Holes) MPG URBAN EXTRA . PASSENGER SEAT SWITCHGEAR Pass Seat Non Memory / Non Height MPG URBAN COMB . KPL URBAN . CORPORATE SWITCHES Glass Corporate Switches PARK BRAKE Mechanical Park Brake KPL URBAN EXTRA . KPL URBAN COMB . HAND OF DRIVE Hand of Drive Right HEADLINING PANEL Headlining Panel - Std CENTRE STACK HARNESS Vantage Centre Stack Harness SPEAKER GRILLES Speaker Grille - Graphite DOORS 2 Doors EXTERIOR DOOR HANDLE Handle Blade - Body Colour SEAT MODULES - DOOR MODULES No Seat Modules - Pektron Door Module IP TRIM KIT IP Trim Kit - Alpine Leather BLUETOOTH Bluetooth REGIONAL CODES FOR CARS 1 Codes For UK ALARM SYSTEM Low Specification Alarm FOAM KIT Foam Kit - Sport Seat Heated & NonHeated PAINT TECHNOLOGY Paint Pricing - Group 10 WARNING TRIANGLE Warning Triangle EXHAUST TAILPIPE FINISHER Bright Finish Tailpipe MANUFACTURERS PLATE Manufacturers Vin Plate - Euro FRONT PARKING DISTANCE SENSORS Front Parking Sensors SEAT INSERTS Standard Leather Seat Insert AFTER PRODUCTION CHANGES AML Standard LICENCE PLATE BRACKET Licence Plate - RoW TMC SUBSCRIPTION UK ITIS TMC Subscription BADGE BONNET / DECKLID Wing Badge Bnt/Deck/d -Bright/Green wing MIRRORS Powerfold Mirror (Memory) SEAT BELTS Seatbelt - Warm Charcoal MODEL BODYSTYLE Standard Codes for V8 Vantage S Coupe SIDE MARKERS Non-side marker ROW UMBRELLA Non Umbrella REAR NUMBER PLATE Rear Number Plate Rest of World SEAT TYPE DERIVATIVE Seat Type - Sports (non memory) ALARM Keyfobs Glass/Plastic - 433Mhz TAIL LAMPS Tail Lamps - Clear SPORTS PACK Non Sports Pack BOOT TRIM Backboard - Non Umbrella / Alpine SEAT HEATING Heated Front Seats KEYFOB COVER No Keyfob Pouch CENTRE STACK CS - Satin Chrome/Satin Chrome Rotary DOOR PULL Graphite Door Pull (Flat Pad) CRUISE CONTROL Cruise Control OCCUPANCY CLASSIFICATION SYSTEM Non OCS PARKING CAMERAS No Parking Cameras Fitted DYNAMIC STABILITY CONTROL - OPERATION Track Mode - 3 Stage Operation MIRROR GLASS Mirror Glass - Right Hand Drive FUEL ADVISE LABEL Fuel Advise Label - Row SEATING ARRANGEMENT 2 Seater BRAKE CALIPERS Brake Calipers - Grey AUDIO SYSTEM Standard Audio TRACKER Tracking Device Cobra CAR TYPE CONFIG CHANGE CONTROL MY90 onwards Coupe codes AIR REGISTERS Air Register - Graphite PEDALS Pedals Silver PASS SEAT HEIGHT ADJUST Non Passenger Height Adjust TAIL LAMP FINISHERS Tail Lamp Finisher - Std Body Colour SATELLITE RADIO DAB Radio IPOD / USB CONECTIVITY IPOD / USB Connection
Old May 18, 2022 | 06:57 AM
sscottdvm's Avatar
sscottdvm is infamous around these parts
I don’t think the MY 2015 has BT audio streaming. You need the Bovee attachment to the iPod adaptor and then it works quite well. I think beginning in MY 2016 it came equipped with BT audio.
Old May 18, 2022 | 01:08 PM
Funny, I had ordered one of those before posting just to cover all bases. It showed up yesterday, and works beautifully. All for less than $100. Thanks so much!
Old May 18, 2022 | 02:31 PM
MRCW's Avatar
My bovee works great. I can connect my phone for calls or streaming, plus an Alexa device. It all works seamlessly, although sometimes it doesn't connect after a gas station restart . Then I just turn off stereo and restart and works fine
Old May 18, 2022 | 10:06 PM
61mga's Avatar
i've got the mr12volt bluetooth device in my 2007 vantage. it also fails to restart after i turn off the engine at a gas station or something similar. i'm wondering if i set it up as instructed with an essentially uninterrupted power supply, i.e. non-switched.
if i can find my work ethic (i've misplaced it somewhere since retirement) i might test the unit's power source and see if it is indeed unswitched.
Old May 19, 2022 | 06:05 PM
a102768's Avatar
a102768 is infamous around these parts
I know a Bovee is cheaper but I presume the later BT module can be fitted to the Vantage?
I was pleasantly surprised to find that my '11 Virage has been upgraded at some point after I spotted a the instructions for it tucked in to the rear of my owner's manual. When I discovered that I shot out to the car and found the extra source option in the entertainment system menu so tried streaming Spotify off my phone.
Old May 19, 2022 | 07:31 PM
Batman-76's Avatar
Batman-76 has a spectacular aura aboutBatman-76 has a spectacular aura aboutBatman-76 has a spectacular aura about
Yes. You can add a Bluetooth module to the earlier cars models.
I added one to my 2012 Vantage S a few years back.
To answer the OPs question when I press the mode button, I see BT as one of the options after installing the module.
I picked mine up from the junkyard off a totaled 2015 Vantage and had my Indy install and program with his AMDS
Old May 26, 2022 | 03:27 PM
Just a follow-up. I've bought the Bovee device and it works just fine. I've seen an option that the dealer can do an entire nav system overhaul and add carplay and whatnot. Does anyone have experience with this?
Old Nov 6, 2022 | 03:07 PM
LuvBurninFuel's Avatar
5 Year Member
LuvBurninFuel is infamous around these parts
I tried BT audio on my 2015 for the first time, all these years never bothered to try it till today. Usually just leave it on Sirius. Click on mode button, go to BT and it automatically plays audio from the iPhone.
hadiofski
Jun 8, 2022 08:16 AM
Geflackt
Apr 1, 2022 06:47 AM
SLVRon
Feb 21, 2021 11:26 AM
StuartO
Aug 4, 2019 04:44 PM
rdennis
Mar 21, 2012 04:21 PM
