ISO Help: 2019 Vantage windshield wiper fluid tank replacement
Old Jan 31, 2023 | 10:53 AM
jeffreyfawaz's Avatar
jeffreyfawaz is infamous around these parts
I recently purchased a used 2019 Vantage and have found that the tank has cracked and is leaking, this seems to be a problem on the previous generation vantage as well. Does anyone have any guidance on if this is an at home project or I should take to the mechanic? Any guidance is appreciated.
Old Jan 31, 2023 | 11:25 AM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
I am not sure this is the answer you want but there is liquid you can put in the tank that when dry it will seal it up perfect. The problem is I cannot remember the name or where to get the stuff. Sorry but a auto parts store may have the answer.
Old Jan 31, 2023 | 12:59 PM
Import's Avatar
Import has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud ofImport has much to be proud of
Well that sucks…can’t help with the repair..but I have learnt to only run winter fluid all year..that way it’s covered to -40…that seems to work..hope it’s an easy fix for ya..
Old Jan 31, 2023 | 07:43 PM
Bob Duato's Avatar
Bob Duato is infamous around these parts
It’s a pretty easy swap but requires pulling a wheel liner. Here’s a how-to video.
Old Feb 4, 2023 | 05:33 AM
Triplb3's Avatar
Triplb3 is infamous around these parts
Cracked windshield washer fluid tank
I have a 2019 DBS, same problem, I bought the extended warranty, so I will let them do it. If I did not have the warranty I would do it myself, it looks manageable.
Old Feb 5, 2023 | 02:26 PM
I_gotta_Vantage's Avatar
5 Year Member
I_gotta_Vantage is infamous around these parts
This will get you to the tank. I would recommend taking pics before removing stuff..
Old Feb 5, 2023 | 02:33 PM
5 Year Member
And you are sure its cracked and overfilled to the neck? The filler neck is just a funnel sitting on top of the tank.
Old May 8, 2025 | 12:22 PM
911ist's Avatar
911ist is infamous around these parts
thanks for the info here! My dealer wanted $1400 to replace the tank...sounds like a scam lol but at least the job seems easy enough to DIY
Old May 8, 2025 | 07:48 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
The sensor went out on last year.
Old May 8, 2025 | 09:41 PM
AM-DB9.2's Avatar
AM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of lightAM-DB9.2 is a glorious beacon of light
I thought I had a cracked tank, turned out to be the rubber hose on the pump for the windshield.
It had 3 or 4 holes like a mouse or rat chew or something starting a few inches above the pump.
Old May 9, 2025 | 06:13 AM
5 Year Member
Repairing the tank should be pretty easy once you get it out of the car.
Old May 20, 2025 | 07:16 PM
SLVRon's Avatar
5 Year Member
SLVRon is infamous around these parts
I had mine replaced last year. My mechanic was pretty sure that a crack in the material couldn't be repaired.
I_gotta_Vantage
Dec 27, 2024 09:06 PM
Argus
Jan 20, 2023 07:51 AM
hadiofski
Jun 26, 2022 09:33 PM
vdk
Jul 25, 2018 10:22 AM
farrbar
May 23, 2018 08:47 PM
