'14 4.7L Vantage S -- Lifter Tick?
Old Mar 3, 2023 | 11:50 AM
PaperBoy's Avatar
5 Year Member
PaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud ofPaperBoy has much to be proud of
hard pass
Old Mar 3, 2023 | 12:52 PM
Anders S's Avatar
Anders S is infamous around these parts
Can't say what is causing the low compression, but I'm pretty sure that is one or two valves on the same cylinder that is making the noise. Either because of clearance issue or spring defect.
Rod knock usually happens every revolution, cam knock happens half of that. I'd put that frequency at < 400 knocks/min, which corresponds quite nicely to half of 750 rpm idle.
The lower compression would have me worried though.
Old Mar 3, 2023 | 04:01 PM
Hybrid's Avatar
Hybrid is infamous around these partsHybrid is infamous around these parts
There are a lot of comments regarding cost.
Just thought I'd mention there is also a time component.
A rebuild is usually 5 to 8 months.
Aston Martin doesn't publish a lot of specifications, and they do not provide a lot of parts, making any rebuild difficult.
Old Mar 3, 2023 | 04:26 PM
MRCW's Avatar
You can likely part it out or put in a new crate engine... even if you 'fix' it you'll never get your money out of it... unless a factory rebuild/replacement it's not a car I'd ever buy, for any money...
I bought a porsche boxster that had an IMS failure but porsche stepped up to replace. I sold the car to another member on this forum with no worries because it was replaced and backed by porsche
Good luck
Old Mar 4, 2023 | 08:52 AM
Wimj's Avatar
Wimj is infamous around these parts
Spring
Originally Posted by embdenb
Dealers are smart and they have resources. If it was a broken valve spring they would know. It’s not that difficult to diagnose. In that case they would fix it and price the vehicle accordingly.
As others have said, if you purchase this car be prepared for and engine out rebuild.
?? Do you think. ??
Laxian Key
Oct 4, 2025 01:43 PM
Hocdoc527
Jul 22, 2015 10:10 PM
Bryce86
Jul 23, 2013 09:57 AM
scottblack
May 9, 2013 10:55 AM
sprinter
Nov 5, 2011 05:58 AM
