Transmission Pan & Filter Kit
I want to do a transmission pan,filter, fluid kit on my Rapide. Does anyone know what ZF part number(s) are for this kit? I used to buy service kit from a ZF parts reseller but last time was over a decade ago and for a different car.
Any service kit for a ZF 6HP should work. When mechanic worked on mine he also had to replace the mechatronic sleeve seal as it was leaking. I had him replace the mechatronic bridge seal and the four little rubber tubes seals at the same time since it was all apart. I don't have part numbers saved, but when I was looking they were common BMW parts. You'll need extra ZF Lifeguard fluid than comes in most of the service kits to handle the extra capacity of the transmission cooler as well.
This is what I have as parts (2010 Rapide with 6HP transmission):
(1) pan with filter ZF 0501216243
(21) bolts ZF 0736101486
(7) liters of ZF Lifeguard 6 fluid
(1) sleeve 24347588725
(1) adapter 24347571211
(2) sleeves 24107519314
(1) sleeve 24107519315
(1) sleeve 24107520715
As of a week or so ago bimmerworld.com had the best pricing.
The kit # is 24152333903K plus the additional sleeve/adapter parts mentioned above.
fcpeuro.com has a complete kit for a bit more # 24117571227KT4
+1 for FCPEuro. Great customer service and fast shipping.
ImHereLive957
Cayenne 958
Sep 18, 2022 11:52 AM
