Jack Mode
Old Nov 30, 2011 | 06:26 PM
ccwboy's Avatar
ccwboy is infamous around these parts
Jack Mode
Do you guy know about the Jack mode.what this for?
Old Nov 30, 2011 | 07:29 PM
stevenrmusic's Avatar
stevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond reputestevenrmusic has a reputation beyond repute
It is for things such as if you jack up the car for servicing such as oil change, tire change, etc.
To enter jack mode, on the center just behind the shifter press and hold the shock and ride height buttons until you see the Jack Mode light up on the center screen behind the steering wheel.
Old Nov 30, 2011 | 09:08 PM
ccwboy's Avatar
i see.this is really great function..anyway have anymore special mode of the button??
Old Dec 1, 2011 | 03:51 AM
Yes, if you press and hold both rear wing up and down buttons the passenger seat ejects. This is great for when you have annoying passengers, especially those who feel they always need to give you directions on how to drive a car.
PS: Of course the above is humor, yet it would make for a good feature/option
Old Dec 1, 2011 | 02:34 PM
Dr.Disaster's Avatar
Dr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to allDr.Disaster is a name known to all
When I first read about this mode in the manual it made me afraid of the car. I thought well crap this thing is so touchy that you have to jack it up special. Not one week into ownership the low tire warning went off and then indicated flat, scared me to death. In any other vehicle I would just be annoyed. I aired it up and made it home. Had it plugged the next day and I'm good since.
Old Dec 2, 2011 | 10:57 PM
F430Spider's Avatar
F430Spider is just really niceF430Spider is just really niceF430Spider is just really niceF430Spider is just really nice
your name must be Ja ck for it to work
Old Sep 26, 2013 | 02:33 AM
Mlee2623's Avatar
Mlee2623 is infamous around these parts
Does the truck had to be on? (Like completely started up)
Old Sep 26, 2013 | 04:42 AM
V12Vantage's Avatar
V12Vantage has a spectacular aura aboutV12Vantage has a spectacular aura aboutV12Vantage has a spectacular aura about
Aparently, if you jack the car without locking the suspension it can / will damage the air suspension struts.
Old Sep 26, 2013 | 07:34 AM
Digger11's Avatar
Digger11 is infamous around these parts
I had an independent mechanic replace a front bushing in the suspension and then 3 weeks later a front air shock sprung a leak. Not sure if coincidental or not. Doubt the independent used jack mode.
Ended up using dealer to replace air shock as just dont trust independent now
Old Sep 26, 2013 | 08:03 AM
I had the same fear when getting new tires at a local tire shop. I went to great lengths to make sure they had to properly jack the car up. I left the manuel on the seat open to the correct page after going over it with the manger.
Old Sep 26, 2013 | 08:09 AM
jc_333's Avatar
jc_333 is infamous around these parts
I always put car in jack mode when getting tire repairs. Don't know about you guys but already had two repairs for embedded nails.
J
Old Oct 1, 2013 | 08:33 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
I used the jacking mode when changing my brake discs and pads recently.
Best to be safe.
Les.
Old Oct 1, 2013 | 06:39 PM
lilo1980's Avatar
lilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura aboutlilo1980 has a spectacular aura about
i always set the jack mode up before handling my car over.
Old Oct 2, 2013 | 07:41 AM
Mlee2623's Avatar
So jack mode in a CTT 05 comes up as regulation switch OFF? Also does the car have to be started up or key just turned to the right in the ignition?
Old Oct 3, 2013 | 03:33 PM
lilo1980's Avatar
I usually start up the car, put it into the jackmode, and shut off the engine.
