GT radio button
Old Aug 27, 2016 | 01:04 AM
dulay's Avatar
dulay is infamous around these parts
GT radio button
Somehow today I was checking tire pressures and when I pushed the select button on the radio to reset tire pressures, the button popped off. The silver outer part of the button I have but the inner blank part with white edge dropped in The car and I cannot find it. I have attached a pic I found online, basically it is the button next to the Select button in the pic.
Anyone know where I can get a new one?
Also on the steering wheel, there is one small side button on the left and one on the right. The one on the left switches on and off the lighted buttons on the steering wheel, but what does the one on the right control?
Thx in advance
R
Old Aug 27, 2016 | 03:29 AM
ExSF's Avatar
ExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to allExSF is a name known to all
Hi dulay.
The button on the right of the steering column is for the heated steering wheel.
Can't help with the other problem, sorry.
Les.
Old Aug 27, 2016 | 04:05 PM
Johnny Hotspur GT's Avatar
Administrator
Hello Remy,
I have the buttons, would you believe each one is different, see picture of 3 buttons lying on their sides and notice the three different cuts of the stems.... now that's ridiculous !!
Now if just your button popped off and the retainer is good, you should be fine, BUT if the retainer is worn or broken for some reason then you must totally breakdown the face to expose the retainer located behind the circuit board, which alone is held down by 40+ tiny screws.
I will trade you for the bumper.....
You can PM me or call me at 908-507-6357, I will also be adding them to my listing in the marketplace.
https://www.6speedonline.com/forums/...arts-here.html
ID:	457542   Click image for larger version
ID:	457543   Click image for larger version
ID:	457544   Click image for larger version
ID:	457545   Click image for larger version
Old Aug 27, 2016 | 07:56 PM
MrVette's Avatar
MrVette is infamous around these parts
Thx in advance
R
The 3 buttons to the right of my steering wheel are labeled as to what they do. So our cars are configured differently.
But I have two buttons un-labeled on the left of the wheel. So I'm guessing these are the two you query.
You got one right. The other button controls the tilt and tele of the steering wheel. It also allows you to set it so the wheel will move out of the way to give you more room when you exit the car.
If you have an owner's manual it gives a good run down on all the button functions. Except it never properly explains the "residual heat" function. I had to look that up on a VW forum.
BTW my steering wheel heater button is actually on the left spoke of the wheel. Not next to the wheel.
Old Aug 27, 2016 | 08:54 PM
Administrator
I believe Remy is asking about one of these switches, I have 3 steering wheels, a 05, 06, and 07, but all three only have the one button on the left bank of switches.
ID:	457568   Click image for larger version
Old Aug 28, 2016 | 05:43 PM
Administrator
For Remy.
ID:	457600   Click image for larger version
ID:	457601   Click image for larger version
ID:	457602   Click image for larger version
ID:	457603   Click image for larger version
ID:	457605   Click image for larger version
ID:	457606   Click image for larger version
ID:	457607   Click image for larger version
Old Aug 28, 2016 | 06:34 PM
dulay's Avatar
Johnny,
This what I have
Old Aug 28, 2016 | 07:23 PM
Administrator
Great !
Please be sure that when you insert the replacement button that you take notice of the position nub at 4:00 on the retainer as shown in your picture, that nub must align with the receiver slot in the chrome ring for proper orientation of the button.
Also as to your brake lights, I would start with a scan, but maybe just a BL switch.
Just a note, if and when you do get the new brake light switch, DO NOT play with the plunger prior to install, as it is a one time use for automatically setting it self when installed.
http://www.ebay.com/itm/141572154535?_trksid=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
cl600bill
Bentley
14
Jan 24, 2023 08:58 AM
artyve
Apr 14, 2016 08:06 AM
18ri
Cayenne 958
Mar 31, 2016 11:15 AM
Garey Cooper
Aug 13, 2003 06:19 PM
