Knocking sound over the Bump
Old Oct 24, 2019 | 11:51 AM
nguyennhatquang's Avatar
nguyennhatquang has a spectacular aura aboutnguyennhatquang has a spectacular aura about
Hello anyone...
I have a problem why my car.. if I'm going over the speed bump at 50km.h or less than that.. I have a knocking sound seem like in the steering wheel on the way to the rack and pinion..
I did replace all of my control arm, Lower, upper, with the OEM TRW one and the problem still the same..
Both left and right side.. the right side heard like Thump Thump..
is that rack and pinion is the common problem making weirg sound in this car...
Knock knock sound...
Thank you alot
Old Oct 24, 2019 | 12:00 PM
Johnny Hotspur GT's Avatar
Administrator
Hello NGUY,
Did you replace the sway bar links, also note that the sway bar mounts have a bushing also, although those are not replaceable, I believe, although others have cut the old one off and used a replaceable piece.
Originally Posted by nguyennhatquang
Hello anyone...
Thank you alot
Old Oct 24, 2019 | 12:05 PM
@johny..
I din't replace it yet because mine is looking fine....
here is the picture of mine
and for my swaybar bushing I did replace it with the the one made by polyurethane from Strong flex...
or are there anyway I can check sway bar link? other than looking at it?
Old Oct 24, 2019 | 12:21 PM
Administrator
Well, my links looked just like yours on my A8L W12, yet they were the cause of my clunking, now some 30K miles later the clunk is back, so I will be checking the links and the SB bushings this time.
Did those hard bushings fit snuggly onto the sway bar without any play ?
Old Oct 24, 2019 | 12:26 PM
@johnny : ok then tomorrow I will remove my sway bar then test drive it short...if the clunking from there then I will let you know..
The bushing fit perfectly and the inside diameter is 31mm.. here is the link
www.strongflexuk.co.uk/front-anti-roll-bar-bush-sport-2233.html#.XbHspi8xWfA
Administrator
When they are new, this split is not there.
Old Oct 25, 2019 | 10:41 AM
Today I remove the sway bar then run it.. the problem still the same...
So I dont think it sway bar link
here is the video thank you
Old Oct 25, 2019 | 11:21 AM
John Fiammetta's Avatar
John Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond reputeJohn Fiammetta has a reputation beyond repute
Something loose to a foreign body in the HVAC system ......fan knocking or flap twitching.
A bump just sets it off .
Old Oct 25, 2019 | 01:42 PM
Administrator
Do you have someone locked in the trunk....
I am with others here, that does not sound like any suspension noise, do like Rico stated and check the front and rear belly pans, also check if wheel liners are loose, that is awfully loud, are your windows up in the video ?
Old Oct 25, 2019 | 07:00 PM
@Rico.Adams and Johny
THe sound only come from the front left actually.. I will check the HVAC line and see what happen...
I drive in Reverse over speed bump no noise.. thank you
all the wheel liner is tight
thank you
Old Oct 30, 2019 | 10:42 AM
@John My windows all the way up..
I did put someone in the back no noise at all..
only from Front Left drive size.. I will check the belly but I don't think anything in there...
did u ever meet the problem with steering rack ?
SoCal69
Apr 24, 2019 08:33 PM
RobbC
May 15, 2012 05:48 AM
gswc32
Apr 23, 2010 07:55 AM
stanmo
Aug 13, 2004 03:00 PM
