window module - single wire mode
Old Oct 4, 2021 | 04:48 PM
molphar's Avatar
molphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud ofmolphar has much to be proud of
Hate to start new topic, but i'm really confused. My rear drivers window is not working as it should. in diagnostics - single wire mode, in usage in is opening and closing you have to press button a lot of times, becouse single press causes only 10 mm or so. when you open fron window, raear one goes down a bit like it should, but when you close, rear is not closing, instead i hear sond of workng motor of FRONT window. AAARRRRGGGGGHHHHHH. thats some sort of bad magic)
and second - fron light washer stuck. is there any working method to fix this for long time?(
Old Oct 18, 2021 | 07:49 PM
molphar's Avatar
And the same thing with TMPS module, i'm wondering what is source of water there and how to prevent that leaks?
@Johnny Hotspur GT , maybe you know?
Old Oct 20, 2021 | 05:46 PM
Johnny Hotspur GT's Avatar
Administrator
Hello @molphar ,
That would be a lot of water to get up to the tpms module, I could see if the module was mounted upside down with the plug on top, and your drivers side rear window is not properly seated and leaking, but with the plug on the bottom, it would have to fill up somewhat to the level of the module to reach the plug and do that amount of damage/corrosion, had did the floor board insulation look under the seats, how is the spare tire well, how are the 2 rear spoiler drains that clog and leak into the trunk ?
As far as the rear window not operating properly, have you removed the motor/module, foam insulation cover to inspect the cables on the window regulator itself ?
Johnny
Old Oct 20, 2021 | 08:38 PM
molphar's Avatar
i think water goes in cable under isolation. i don't know another way( now car is in service becouse ive got migraine and can't see daylight)
A have problems with tubes under spoiler after changing trunk with hole for close button. but now thay are fixed
i have some photos
Spoiler
And first dead block
Spoiler
Rumster
Mar 10, 2015 04:12 PM
TRM
Dec 11, 2014 11:40 PM
timwhayden
Oct 15, 2013 07:44 PM
marsfire
Aug 26, 2011 12:01 PM
skandalis447
Nov 16, 2009 07:10 AM
