Dension GW500 installation issues - need help
Old Jun 3, 2009 | 08:14 PM
MTRX's Avatar
MTRX is infamous around these parts
Today I was trying to install my new GW500 on my Cayenne S with Navigation and CDC.
It looks like something is wrong with my GW unit. I did a lot of troubleshooting today and confirming that when unit is set as “SERVICE MODE” (switch) CD changer works fine and the entire system works as well, however when you switch from SERVICE MODE back to GW mode I get an error on the screen of my PCM telling me that Amplifier is not available. Also, when you GW mode there is no light in the fiber line which is outputing back to CDC, however once you place switch back to SERVICE MODE you get light instantly…
I even tried the reset button on the accessory that has a switch for service. But nothing helps.
Old Jun 4, 2009 | 09:57 AM
ChkbookMechanic's Avatar
ChkbookMechanic is infamous around these parts
These might be some basic questions, but it always helps to start at the beginning...
How did you run the MOST wires? From what you are describing it sounds like you haven't connected them the right. When the unit is set to 'SERVICE MODE' the GW basically disables itself. Did you set the DIP switches on the GW500 correctly?
Old Jun 4, 2009 | 12:57 PM
MTRX's Avatar
I actually just figured it out. I used a wrong MOST cable. There are apparently 2 on the back. One that goes into your AMP, which is the visible one and easy to get to and one that is behind your CDC.. I didn't realize that there is one on the back of CDC, so instead of removing all the panels I actually was able to stick my hand in there and disconnect that MOST cable from the back of CDC and connect a different cable. It was challenging as there was no space to maneuver but after few tries I was able to plug that MOST cable back in
Old Sep 24, 2017 | 02:25 AM
clam1030's Avatar
clam1030 is infamous around these parts
Hi All, it has been about 3-4 months since I installed the Dension Gateway 500S BT on my 2006 Cayenne S with PCMI and 6-cd changer. Installation went through without a hitch and I've had 3-4 months of no issues.
Today, I started experiencing an odd issue: The system seems to reset at random - music playback stops as the bluetooth disconnect for a moment and resumes playing again. This happens with AUX plug-in as well. I then switched to standard FM radio and even that stops. Every time the music stops (whether it's BT/AUX/FM-radio) I hear the head unit trying to load a CD then I'm met with an error screen saying "CD Changer cannot be found".
Any ideas?
Old Sep 25, 2017 | 05:23 PM
deilenberger's Avatar
deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !deilenberger Is a GOD !
Any ideas?
Take the Dension out of the circuit and see if it still does it. If it does it points to one of the original components acting up.
Old Sep 25, 2017 | 05:57 PM
clam1030's Avatar
Thanks for the advice in helping to diagnose here. I turned "bypass" off on the Dension to try this - I assume this is equivalent of taking it out of the circuit. When that happens, I get no audio at all.
Old Sep 25, 2017 | 07:07 PM
No - that's not exactly the same. The MOST buss still has to pass through the in/out coupler in the Dension. If the coupler has a problem - it could account for the symptoms you're seeing.
The trick to troubleshooting is to isolate where the problem is - to do that - put the system back to factory configuration and see if the problem still occurs. If it does - then it's one of the components in the factory system. If not - then it's the Dension. The fact that it's resetting even on FM makes me suspicious that it's the radio itself or one of the amplifiers. The radio has been known to cause intermittent problems like this that eventually become full-time problems, but without isolating it to at least factory/vs/modified - it's all guesswork.
Old Sep 25, 2017 | 10:05 PM
clam1030's Avatar
Thanks for taking the time out to give the background on the lesson to be had. Part of me is having the debate to replace the entire head unit with a Pioneer and aftermarket amp (JL Audio or something else). After posting to this thread I did a bunch of searching and I'm highly considering that now unless I can get this Dension to work again - only issue is it looks to be a $2k project.
Old Sep 28, 2017 | 06:15 AM
Juanna Knowtrooth's Avatar
Juanna Knowtrooth is infamous around these parts
Could always try an EBay android head unit...
http://www.ebay.com/itm/Android-7-1-...5Ziu9P&vxp=mtr
They have come down in price quite a bit. I haven't actually had any experience with one, but would be interested if anyone has
Old Oct 16, 2017 | 12:12 AM
clam1030's Avatar
Issue Resolved!
Hi All,
First of all...huge shoutout to Eric @ BumperPlugs.com. I have never gotten such great service from a retailer before. As soon as my issues surfaced, he worked with me pretty much every other day for 2 weeks to resolve it. After getting a replacement unit sent out to me...an official notice from Dension was put out identifying iOS 11 being the culprit for the issue.
As Eric identified in his thread (https://www.6speedonline.com/forums/...sbt-issue.html) it just requires the user to decline/reject phonebook syncing. That solved everything!
COBB Tuning
Jan 1, 2025 09:02 AM
pilotscottb
Sep 1, 2015 10:29 PM
tkebp1275
Aug 31, 2015 06:35 PM
OldBoldPilot
Aug 24, 2015 04:00 PM
metzkaro
Aug 24, 2015 02:59 PM
